My first Hendey 12x5 ECM
vincentg
Apr 5, 2023
Hey guys, I just picked up my first big boy lathe, a Hendey ECM 12x5. She appears to be in great shape with minimal wear, but the headstock is very tight, I'm sure due to the adjusters being cranked down. I will start the tear down soon. Serial #26588 if Hendeyman is looking. The p/o said he purchased this lathe from a shop his uncle worked for where it was used for many years.
She came with this box, which the p/o told me was a rare find.
He also did a very nice job with paint and to add contrast with nicely turned brass spheres to replace the factory oil point screws. Still have to order a VFD to get it powered up, but I think the spindle is the first thing to tackle. I was looking at an 11" Precision Mathews before I found this American classic. Should be worth the extra time in the end. This is an amazing machine that I am proud to have in my home shop. P
animal12
Apr 9, 2009
CA USA
Nice lookin machine . Is that where the motor is mounted ? Don't think I've ever seen a motor mounted in that location . SO what do you have between centers ? Looks @ 24 - 27
thanks
animal
johnoder
Jul 16, 2004
Houston, TX USA
Common Hendey ailment - not something you adjust but FIX when you have it apart. Here are some related scans, though for a cone head
vincentg
Apr 5, 2023
I'll measure later but that sounds about right. The motor mounts where you see it. I was under the impression thats where all ebm and ecm motors were located.
vincentg
Apr 5, 2023
Thanks for that great breakdown. I am hoping I just need to shim it out as I have read. I was really happy when I found it has the tapered bushings as I am hoping to use the machine for turning precision fit bores and pistons. From what I understand it should not leave the impression of the spindle bearing like some others.
johnoder
Jul 16, 2004
Houston, TX USA
More related scans ( though EBM)
vincentg
Apr 5, 2023
Good stuff! The machine came with a gearhead manual so I'm looking for a full ebm/ecm manual.
