snowshooze
- Sep 15, 2010
- Anchorage, Alaska, USA
Hi Guys;
Does anybody have NPT blanking dimensions they could share or direct me to?
I used to cut drill joints and the Drillco handbook had them.. Box and Pin rotary shoulder blanking dimensions..
And they had NPT in there to.
That book is expensive if you can find one.
It is so much easier to bore the taper ( on ID ) clear to finish at taper, and then a few trips through with the threading bar.
Mostly, if I have a sample, I'll just go off it and in the case of ID stuff, just with a caliper and go.
It is a lot faster than working with pitch diameters and all the un-necessary foolishness.
Bore it, thread until you get engagement correct..
Thanks!!!
Mark
Thanks!!!
Mark
