Need advice for pulling this lever off of lathe gearbox
jackal
May 4, 2006
northwest ARK
I bought this lathe a while back and it has some feed problems.
This handle needs to come off to get into the gearbox.
Can someone tell me if that center threaded hole is a puller hole?
I've seen these types of levers on machines, but never really thought about it.
I removed the 2 large set screws, and it looks like someone has already ran a short set screw in there and it fell sideways.
Looking at the covers and plates, it's obvious that it's been apart before.
Thanks for any info.
jackal
May 4, 2006
northwest ARK
Is it possible the lever assembly comes off with the access plate? I was into one of my lathe gearboxes a couple months ago, the lever came off with access plate. Only way to remove the lever was from the inside.
There is an aluminum threading chart behind this lever.
The chart has to come off to expose the socket head bolts for removing the plate.
jackal
May 4, 2006
northwest ARK
Thanks for all the advice.
This morning, I went left -right several times with the lever and it twisted off.
Look like those large screws with the detent balls are supposed to limit the movement.
Without the balls/springs in there, thr lever was turned past the normal limited position.
I'll post later once it is apart.
Thanks again.
Bill D
Apr 1, 2004
Modesto, CA USA
Since the balls and springs are lost I will chime in and say you can make a brass rod of the correct diameter and round over the end. Then turn the shank down so the spring fits over it. It ends up looking like a mushroom.
Springs I have found some in single lever faucet seal kits. Ball point pens are usually too small for much.
Bill D
jackal
May 4, 2006
northwest ARK
Bill D
Thanks Bill.
I will probably make some of those 'mushroom pins'.
I have a box of old springs that I think I can cut down to make the ones I need.👍👍👍
jackal
May 4, 2006
northwest ARK
Most springs, most places, were selected from 'stock items', not custom-made.
If No Joy in yer "Hell box", and since it could last AGES if done well, it could be worth the effort of an order:
They "have balls", too..
:D
Yeah, It might be easier r to just add to my next McMaster order.
Bill D
Apr 1, 2004
Modesto, CA USA
Thermite one reason for my suggestion of using brass is if it gets messed up it will not do too much damage to the irrplacable machine parts it fits into. Much safer choice then a hardened ball bearing. Especially true when there are no real plans to measure up the new parts being made to fit.
Bill D
dalmatiangirl61
Jan 31, 2011
BFE Nevada/San Marcos Tx
Bill D
Its divots in a steel plate, as for size, measure the hole, choose a ball bearing and spring that fits the hole closely.
Bill D
Apr 1, 2004
Modesto, CA USA
True on the lack of wear now. But I would rather pull a brass pin out and make a new one on the bench then have to kneel down and drill/ream/make/install a new seat or bushing and risk gettting swarf into the gearbox.
Bill D
dalmatiangirl61
Jan 31, 2011
Bill D
The divots are not inside the gearbox, they are behind the lever, on the outer surface of the access plate. In a worst case scenario, you take the access plate off and repair it on the mill, or just fab up a new one.
MrStretch
Mar 20, 2017
If the original pieces are missing it doesn't really matter what you replace them with as long as it works in the end. Personally, I would try to make new parts before mail ordering some potentially useless parts because a babbling AI told me to.
Yes, brass will wear faster but who cares? There is absolutely no fault in carefully considering how your alterations will affect existing hard to replace/replicate original parts.
