Need Help calculating change gears on Clausing Colchester model 600 vs12 lathe.
wadesr
Jan 19, 2019
I have the Service and Part manual which has formula to calculate gear change. I must be loosing gray matter because it just doesn't click. My machine has the English pitch leadscrew. I'm trying to figure if I can cut metric threads on it. I have a bunch of gears, both phenolic and metal. machine currently set up in L configuration.
johnoder
Jul 16, 2004
Houston, TX USA
Here is some thinkng on the subject. Say your lead screw is 8 TPI. Say also your QC gear box lists 8 TPI. I can theoretically stick in exactly two gears together as a two gear compound and imedtialely cut a 2.5mm thread. Those two gears would be 127 and 100 teeth - and they would have a ratio of 1.27 to 1. 1.27 divided into the .125 (8 TPI lead) will equal 0.098425197 - which just happens to be a 2.5mm metric thread. The practical problem is get such a pair of gears in a position where they can do some good
john.k
Dec 21, 2012
Brisbane Qld Australia
The Colchester books are generally written for the UK delivery models,the US and some Canadian delivery models (Clausing?) often have a different feed gearbox ratio set......In general the UK and world delivery models have a metric /imperial change lever in the gear,generally the last gear train onto the leadscrew..............However ,if you have a 127 /120 ,or 127/100 gear combination ,you can translate metric pitches with a 8tpi lead .........there are other ratios ...80/63 etc ,etc.
wadesr
Jan 19, 2019
Thanks for the replies. My machine has a 4 TPI leadscrew. I know the gears are 14-1/2 P.A. and 5 D.P. I have all the US version gears, now I just need to find some 127/100's and EDM the ID. I start at Boston Gear!
john.k
Dec 21, 2012
There is no way your gears are 5DP......this is truck gearbox size teeth......as well as being a rather odd size.......I d suggest more likely 12DP ,14DP or 16DP......with 16 DP being a common Colchester change gear size on the smaller lathes .......my big old Swift has 10DP change gears .
johnoder
Jul 16, 2004
Houston, TX USA
A way to look at that is to visualize how many 5DP teeth fit on a 1" diameter circle - the answer is 5 :D
