Deude-Mann
- Mar 27, 2021
Good afternoon all
I need help identifying this motor for bearing replacement.
Background:
I have a large surplus Baldor three-phase motor that is being used as an idler motor with a North America CF-30 phase converter panel. It is all installed and running, except that one or two of the bearings on the motor are howling when running. I have lubricated them through their grease fittings with the proper grease and there is still no improvement. The motor starts and runs fine except for the bearing noise.
Long story short I can return this motor with some hassle; the supplier is not local, and is a 250 mile drive one-way. I could also replace the bearings myself which may be the easier approach overall; the motor supplier has offered to pay for the bearings and labor. I have the tools and knowledge to replace the bearings as long as they are nothing strange and are readily available. However I do not want to tear down the motor to get the bearing numbers directly since the motor is under warranty so to speak.
The tiles in the photo are 12"x12".
Does anyone know how I can get a part number for this motor or the part numbers for the bearings? All the information I have is in the attached photos. Thanks
Background:
