Need info on these monster grinding bits
Cannonmn
Jun 25, 2016
Here’s one of some unusual grinding bits we found. Length 3”, solid shank dia. 5/8”. The stone looks like some we have that are supposed to be diamond-impregnated. What would be a typical use for these? I thought maybe jig grinder but I don’t know if jig grinder chucks hold anything that big, typical jig grinder stones I’ve seen had 1/4’ shanks. So, what rpm limit, what application?
ADFToolmaker
Mar 12, 2012
Hamilton, New Zealand
These look like pins for ID grinding on a cylindrical grinder. They would fit my my machine. Could be jig grinders out there too that they would fit. More likely to be cbn rather than diamond.
Cannonmn
Jun 25, 2016
Thanks, I haven’t found any markings so how can I determine the basic composition of the abrasive by appearance or testing?
I’d compare the appearance of mine to other thick-shank pins on the web, particularly any 5/8 in. Shank, but I haven found any for sale. I’d like to do that because I’m pretty sure there are a very small number of manufacturers making 5/8 in. Shank bits, and maybe their heads will,have a distinctive appearance. One thing about those I have is that the head is coarse-looking as opposed to the super-smooth examples I see on the web.
Cannonmn
Jun 25, 2016
Here’s a better image where u can see the roughness, variegated coloration. I use this link so the image won’t be reduced by pm software. There are large grains of something visible.
Flickr: Page Not Found
Milland
Jul 6, 2006
Hillsboro, New Hampshire
They might be bespoke composite router bits. Things like fiberglass and the like.
If you look at the grit under a microscope, you "might" see some evidence of translucency if it's diamond, opaque (I believe) if CBN. This can vary depending on how the grit was treated prior to brazing, if metalized nothing might show until the free side metal was worn off.
But I'd bet they're diamond over CBN. Just a guess...
[This reference seems to state that CBN is transparent, but that may be just for thin homogeneous films, not grains for grinding purposes: "Because c-BN is transparent within the wider wavelength, another usage of c-BN will be in a protective coating for optical elements, particularly optical windows, for example, of ZnSe and ZnS."
Cubic Boron Nitride - an overview | ScienceDirect Topics ]
eKretz
Mar 27, 2005
Northwest Indiana
They could even be tungsten carbide. About the only way you could do even basic testing yourself would be to see what one can cut and how fast it wears out. Try one on a carbide insert and see if it cuts. If not then it's probably tungsten carbide grit. If it cuts decent at first but dulls and slows down pretty quick it's probably CBN. If it's cuts really good and keeps cutting it's likely diamond.
Being that coarse I'd bet they're routing bits also. Probably for composites like G10 etc. I'm thinking they're electroplated, not furnace brazed.
Cannonmn
Jun 25, 2016
Thanks, for testing I’d need to use a realistic rpm but have no info nor experience with pins like this. Or would the performance be independent of the rpm?
eKretz
Mar 27, 2005
Northwest Indiana
You probably won't be able to spin it fast enough to reach optimal speeds, just spin it as fast as whatever you have available that can hold it.
Cannonmn
Jun 25, 2016
We could do 150k rpm on the Moore jig grinder but unfortunately it isn’t hooked up now so we’ll have to settle for die-grinder speeds, maybe 30k rpm no-load, and make an adapter to hold the 5/8 diameter shank.
Milland
Jul 6, 2006
Umm, having tossed a long bit when over-enthusiastically using it in a router, I'd discourage you from trying to make an adapter to hold a heavy bit well outside the collet of a 30K machine. Router collets are usually pretty weak for their RPM (unless a quality 1/2" or so), and there's a lot of energy present if the bit/adapter goes flying.
If you do try it anyway, clamp the router behind a steel blast plate, and remotely plug in an extension to keep yourself out of the firing line.
And film it...
Cannonmn
Jun 25, 2016
And film it...
Good to know, so I’ll settle for whatever the BP will do, think 3800?, since we could put it in a 5/8” R8 and have few worries.
Cannonmn
Jun 25, 2016
Ok finally have one in my hand. There are markings in two lines
07958719882 or maybe last digit is 7
and
D13703S
The last number D13703S IS ON A WHITE STICKER ON OUTSIDE OF THE LIL PLASTIC BOX EACH ONE LIVES IN. CAPS KEY STUCK
