Need info to figure out a gear cutter
kirk05
Aug 9, 2021
I posted before and got some great help with a DP2 involute gear cutter. Now the problem is I need to try and figure out what involute gear cutter I need to cut these smaller splines. The only info I got on the blueprint is external spline B 58x53 DIN 5482. Looked all over on the internet but can't seem to find any answers. Can anyone help me to figure out what size cutter I need? I would really appreciate the help!
Dan from Oakland
Sep 15, 2005
Oakland, CA
You don't specify internal or external but for the external :27 teeth, major dia 57.5mm, minor dia 52mm, pitch dia 54mm, tooth thickness 3.741 mm, 2 module 30 deg pressure angle.
Call Ash gear, they may have a space cutter available.
kirk05
Aug 9, 2021
Yes sir the print called for external spline. Thank you very much Dan I'll try giving them a call in the morning! The 30 degree PA is what's messing with me. All I could find was 20 degree cutters and just thought I was missing something. I appreciate your help!
