Need software solution to turn photographs of 2D shapes into .dxf/.dwg.
Question Boy
May 11, 2005
Napa, California
I'm using Solidworks at work to make 3D models/drawings for typical machine shop use, but they're asking me to do something new: I need to take physical 2D patterns and create Solidworks drawings for them, they're like sewing patterns, so doesn't require close tolerance. But, there are a lot of them, so I need to be more efficient than I can be by measuring out each one with a ruler. I started to googling for software that can import a picture and kick out a .dxf, and I'm getting lost in the options.
Anyone already gone through something similar? It's a big enough job to justify buying software as long as it's not crazy expensive.
QB
604Pook
Sep 14, 2022
My buddy does it for me using Adobe illustrator some how. I have the program too, but have never had the time to learn it.
I usually have some clean up to do once I pull it into Solidworks. Another option I have done as well, is if you have Adobe Illustrator, and also Solidworks, you can open .ai files in Solidworks, and use it for tracing things.
snowman
Jul 31, 2004
Southeast Michigan
I used to just take a photograph of them with a scaled ruler then trace the lines in autocad. I never found that the convert to dxf programs available did it in such a way that they made closed lines that the laser or plasma understood. It was faster to just trace.
Expect some parallax distortion. It doesn't work for amazing precision. I'd usually use a combiation of it, and hand measuring.
Apr 14, 2018
Totalitarian Ruling Capital, EastAsia
Almost any graphics program can do this, I think even Mastercam and definitely Illustrator, CorelDraw, and even Inkscape (if you can keep it from crashing). But it sounds like your problem is, you need to do a lot of them and would rather not have to do each on by hand?
Got a good computer guy handy ? Ras2vec will convert from bitmaps to something you can deal with, I'm thinking GraphicsMagic will allow you to automate batch processing of a bunch of photos, and the guy who maintains it is super helpful. More upfront trouble but setting up to do automatically might be worth the hassle ?
And as snowman says, you're probably going to have to run the dxf's through a repair program at the end, too. Or do it by hand :)
memphisjed
Jan 21, 2019
Memphis
illustrator. It has a technical drawing trace setting that works well.
bad is adobe is subscription only for illustrator now. If you can find an old copy hold it dear.
Volitan
Sep 16, 2006
Long Island, New York
I don't have a recommendation better than what's been posted but wanted to point out that getting a program like Gimp (free) or photoshop and learning to sharpen or soften the image as needed will be a big help. It will help get rid of extraneous stuff when you import it.
Haven't read the whole thing but this looks like a good tutorial:
Marvel
Jan 14, 2019
Minnesota
I do it in Adobe Illustrator, I can take any image, create outlines and export as a DXF, and am able to open in SolidWorks.
car2
Sep 19, 2009
Apex, NC
I use CorelDraw (an old version) for things like that; it's great at working with and coverting image and vector files, and is not a "graphic illustration program" (which I don't need), but will do a lot of graphics functions also. It just works very well for what it is designed for. It has various "trace" functions for images.
That being said, you will get much better results if you can scan the patterns first, versus taking pictures of them, even if you have to scan in pieces and stitch together. I have an 11x17 scanner, and you could probably find a large format scanner at any print shop where they'd do that for cheap (and may even have ready-made software to do exactly what you're trying to do). Cheers.
Doug
Dec 16, 2002
Pacific NW
I use Cutting Shop from Arbor Image. Used to be around $300+. Produces nice dxf's with arcs, lines. It's the best I could find in raster to vector software. It doesn't output dxf's with billions of short line segments like graphic software typically does. In graphics where objects are printed it doesn't really matter if a circle is represented by a thousand short line segments.
I started using it way back in the day when my machines had very little memory.
No matter what raster to vector software you use it'll need some cleanup, editing. Line crossings seem to be the main cleanup needed.
DanielG
Oct 22, 2014
Maine
I've done some of these. I've never had great luck with the automated raster to vector tools. I just import them into SW as a sketch picture and trace things with splines. You can also tweak the outline to match measured dimensions.
If the pattern is small enough, a flatbed scanner is going to give you a less distorted image than a photo.
Apr 14, 2018
Came across another one, never used it but Turbocad is an established company, almost all scanners nowadays will scan to pdf, this is $200
