Oldwrench
- May 21, 2009
- Wyoming, USA
The latest Haas VMCs come with automatic doors whether you order that option or not. Interestingly, whereas before the spindle would turn up to 750rpm with the doors open (useful when using an edge finder or a co-ax indicator) now it will not run at all unless the doors are closed. Perhaps they assume you will not be using anything so old-fashioned as an edge finder...but if you didn't order a probe with the machine you can't find work locations. Duh.
I recently visited a friend's shop in the Denver area (anonymous, for reasons which will become obvious) who had run up against this problem. No probe, but automatic doors that they hadn't ordered. The guy was kind enough to show me this workaround, utilizing a maintained-contact button switch that fits in the plugged hole normally occupied by the connector for the remote handwheel: Button out=the control thinks the doors are open; button in=it thinks the doors are closed. Cycle the button in and out once to boot up. After that, you can do whatever you want except that it must be in the open position for the lights to come on and/or to change tools manually. Push again to turn them off and run the program. Obviously some temporary disabling of mechanical elements is also required, but they tell me that is easily re-enabled if one uses the same electrical connectors as the original. Why bother to reconnect it? Because an HFO technoid is apparently not allowed to work on a machine whose interlock has been circumvented.
Anyway, the way the machine came was probably an "engineering oversight" illustrating the Law of Unintended Consequences—but these days, who knows? The above information is passed along in the spirit of educating the consumer, and is certainly not intended to help a devious machinist defeat any safety features. To that end, critical details have been deliberately left out.
