New Haas TRT160, TRT210, Are they rigid enough for heavy aluminum drilling/milling?
BP0650
Feb 14, 2022
We are looking to add one of the new TRT's to our vf2ss to replace a HRT210. I am worried about rigidity and brake torque.
My main concern is in the op shown we will be running a 1" insert tsc drill through the length of the billet in the shown position. We are currently doing this on a traditional 4th axis rotary with no issues. However I am concerned with the adding of the additional axis and the way the force would now be distributed that we may run into some issues. Is anyone out there running these new TRTs? Do you like them? Are they rigid enough with the A at 90? What do you mill on it?
We would be getting the break booster to assist no matter what but this is a very expensive addition for it not to be able to perform as needed. There are ZERO videos other than one from haas were they take any thing near a "heavy cut" or drill on the new TRT.
BP0650
Feb 14, 2022
My only concern is the TRT only mounts via one side unlike the TR200Y that mounts on both sides. I actually looked at one of the TR200ys but we need more part swing.
Milland
Jul 6, 2006
Hillsboro, New Hampshire
A Haas applications rep should be able to take the geometry you've drawn and the specs for the drill size/speed/feed and calculate the margins. Check with them and get a "written guarantee" of suitability before making the purchase.
BP0650
Feb 14, 2022
I was not aware they did that, I will reach out to see if I can get something in writing.
Milland
Jul 6, 2006
Heh - they may whine, but they can do it. Put the screws to 'em if they bitch about it.
At worst, you may have to supply the nominal value for drilling force (something the drill vendor should be able to get you), but the torque ratings on the trunnion are straight forward when the Z load is known.
EMTech
Feb 10, 2022
South Bend area
The TRT160 and TRT210 are surprisingly rigid. I like them a lot better then the TR series because the design offers more clearance. The TR200Y series requires a safe tool change position that adds a lot of extra time to the tool changes. You can use a safe tool change position with the TRT series if needed, but the distance that you will need to move will be a lot less. I have run a lot of 17-4ss and titanium alloy 6al-4v in the TRT160 with no problems, but I was not using a 1" inserted drill either. The biggest drill I used at A90. that I can remember was around .360". It was a solid carbide coolant through drill into 17-4ss. I didn't have any trouble with it, but that isn't close to a 1" inserted drill!
The TRT100 is pretty weak, but faster. The TRT70 is next to worthless as far as rigidity is concerned. Just my opinions...
EMTech
Feb 10, 2022
South Bend area
Could you elaborate on that? What do you suppose it's limits are? I'm considering getting one for my CM-1; I do small medical device parts.
Thanks
I can get you a good deal on one (or two) from a company that tried to use them! They were also trying to use it on a CM-1. I don't know if it was ever actually used.
The rigidity issue is that you can see several thousandths of movement by pushing on it by hand. I can't remember how much, but I am thinking it was over .005". I can double check with some of the guys who were heading up this project if you want to know a better number. This also caused poor surface finishes.
The other issue is the platter weight limit restricts the use of most off of the shelf fixturing. By the time you get the chunk of material and the fixturing, you are over the weight limit.
Let me know if you want more info or if you are interested in buying one. I can check to see if they still have them available. I do know that they were wanting to sell them.
mhajicek
May 11, 2017
Minneapolis, MN, USA
Yes please. I should be in the position to buy one in a few months, and my parts are small enough (a few grams) that it just might work ok. I use a lot of 1/32 and smaller cutters. I'm currently using an HA5C-T, and my machine is 5 axis ready. I used a TR-160Y at my last employer, but the parts were much larger.
Thanks!
mhajicek
May 11, 2017
I did find a self-centering vise that fits inside a 4" circle, and weighs 2 pounds 4.0 ounces. I'm sure I could lightweight it a bit.
EMTech
Feb 10, 2022
South Bend area
Thanks!
There are two available. They are asking $16,000 for each unit. It does sound like there is some flexibility in that price. They have had very little use.
implmex
Jun 23, 2002
Vancouver BC Canada
Hi mhajicek:
Not to hijack this thread completely, but are you looking to mount blocks on a 5 axis rotary like a TRT 70 via a dovetail with this tiny self centering vise?
If so, you may do better if you're weight conscious, with a lump of titanium that has a female dovetail wired into it and a flex clamp instead of that vise.
You just have to make all the dovetails on your workpieces the same to accommodate the limited clamp range...no big deal.
It's the method I've chosen for much of what I do. and it works very well.
It's also cheap and versatile...you can make the mount any shape you want so you don't have to hang the cutters out very far to still reach your part.
There's no need to make these on the wire EDM either...it's a convenient way but you can mill them too.
Cheers
Marcus
Implant Mechanix • Design & Innovation > HOME
Vancouver Wire EDM -- Wire EDM Machining
mhajicek
May 11, 2017
Hi mhajicek:
Cheers
Marcus
Thanks, this is a viable option.
