sirAIG
- Jan 10, 2019
- State College
I run a small mainly prototyping business out of my home shop. Have a few newer Haas machines and a plethora of manual equipment. Currently my only legitimate stock cutting option is an early 90's Scotchman cold saw. GREAT saw for certain applications, but due to how hard it got used by my father, it has a lot of slop throughout and is not suited well for munching through thicker (1" and up) stainless bar. The slop results in uncontrollable "chatter" that I believe to be killing blades WAY too soon. I will be getting a job here soon where I will either need to make 1000 cuts in 2" x 1" 316ss bar OR pay someone else to cut it (There are also around 3000 other cuts in 316ss, but much smaller bar). I attempted to get a proper blade for the scotchman and after roughly 10 cuts the blade was already hurt and required a lot of leaning on the handle to make some unhappy cuts.
My father has an Ellis 1600 at his current day job which he speaks highly of - my issue mainly is that I want to be able to run this thing with flood coolant and surely I can make up a pan and hook up a pump, but from a bit of research I've done, the Ellis saws are "not meant to be run wet" - unsure exactly why - if it is due to issues with the saw itself, or due to the fact Ellis does not make or sell even add-ons for flood coolant.
I would like to stay US made, MIGHT consider taiwanese depending on reputaion and parts/long term support. I'm sure I could get more for my money finding something used, but considering I will be relying on this thing from day one to meet a pretty tight deadline on this job, I am pushing that thought aside in lew of having "reliable, problem free" operation out of the box.
I realize I will need to be tending the saw for days on end to cut all the stainless I need, but that is a non-issue for me at the moment. I rarely ever see quantities over 20pcs - I can position the saw directly beside the machines I need to tend and keep everything running efficiently.
I have been looking around a bit and stumbled across the Do-All DS-280m.
www.doallsaws.com
Does anyone have experience with this saw, know someone who does, and/or have experience with similar, "new" saws from Do-All to have an opinion on if this is worth the ~$5500 dollar tag I have seen it listed at?
What other saws should I be looking into?
I appreciate any help or guidance that anyone can provide! If there is a section on the forum that would yield better results, please let me know and I will move it.
DS-280M Band Saw | Manual Bandsaw, Horizontal Metal Band Saw | StructurALL
The page features the DS-280M manual, dual miter, metal cutting band saw by DoALL. Learn More.
