Our shop got a new Smart NL200BSY lathe with live tooling, Y axis and dual spindle.
Also got a new EDGE Rebel 80 bar-feeder.
Anyway I've got the 1st part proved out and making good parts without the bar-feeder using chucker mode.
It makes side 1, then the rear B axis chuck comes and spindle sync's to main chuck, pulls out the bar, then parts-off the part, returns to it's home and then the backside is faced and chamfered and spit out to the rear catcher, then the material is already positioned to make a new part.
Now I need to incorporate the bar-feeder and I have it set up to feed the new bar to the correct position and I don't have a clue how to add the bar change to the cycle, I've only used an old pneumatic bar feeder. How do I make this work??? Should the bar-op program be at the start of the program or the end? Any examples you can share?
