New to me 20" Lodge & Shipley lathe. Information needed.
pompeiisneaks
Aug 20, 2021
I have a Lodge & Shipley 20" lathe from the 1925 era. (I've had the machine dated via the serial number stamped on the ways). Monarch doesn't support that old of a lathe. Wondering if anyone has any details on the parts/components like drawings or service manuals? I think I have all the parts but not 100% sure. I'm starting the cleanup as it was in a garage for who knows how many years collecting dust and a bit of rust. I might have to scrape the ways and slide back in, not sure at this point, but that's all new to me, but am willing to take on the challenge to restore this old beast. It also has an old GE motor on it 3 phase at 440 VAC, 7 1/2 HP but has details on it how to rewire it for 'lower voltage' I'm guessing/hoping that's about 220 or so. I might be able to get the old model number off the plate of the motor but it's a bit dirty still so I'll have to clean it up. Any information people have would be great. I do know of vintagemachinery.org and I found a doc that seems to be perfect for this timeline and it has a few images etc, but no closeups or detail on the parts themselves. Just overview shots.
Posting a few pics of the old beast.
Thanks!
~Phil
johnoder
Jul 16, 2004
Houston, TX USA
Thanks!
~Phil
Lots of them - just referred to as Selective Head. Here is a scan from 1916. Thanks to member Mike C. for the scans
Manual just about useless
Some L&S threads of mine are here
pompeiisneaks
Aug 20, 2021
Thanks for the info all! Sorry I figured it should go under the monarch area since monarch owns the trademarks now. I have the tailstock, it was not on the lathe when I got it, and it's a heavy beast so I figured I'd leave it off and clean it too, and when the lathe's ready to start making chips I'll get that on too. It has the cross slide, steady rest, etc. Just need to do a ton of cleaning. There seems to have been some kind of taper attachment that I 'might' have parts to as well, but it's hard for me to say without a good machine diagram and exploded parts list etc. There may be a decent amount of missing bolts etc, but I'm guessing that's not going to be hard to replace. In playing around I can see that the speed selectors work to gear it up/down etc. The threading slider is working but slow to move so I'll need to clean that all out as well. The ways are pretty crusty but as I've cleaned them a bit they still seem pretty decent all in all. Does anyone know for sure if that type of GE motor's 'low' speed is 200, 220 or? I think back that far 200 or 220 is more common than 240. I'm guessing I'll need to find a way to drop it a bit to be sure? I think I've seen some VFD's that do lower output, but I'm thinking of getting a rotary phase converter instead, but not sure if you can lower the voltage with those? Maybe by intentionally under-filtering a bit with the run capacitors?
Again, thanks for the help and info!
If people are interested I can do more like videos or photos of the beast as I go? I've done tons of youtube videos for my other hobby of hand building tube guitar amplifiers :D
~Phil
Cal Haines
Sep 19, 2002
Tucson, AZ
I have a Lodge & Shipley 20" lathe from the 1925 era. ...
... It also has an old GE motor on it 3 phase at 440 VAC, 7 1/2 HP but has details on it how to rewire it for 'lower voltage' I'm guessing/hoping that's about 220 or so. ...
... Does anyone know for sure if that type of GE motor's 'low' speed is 200, 220 or? I think back that far 200 or 220 is more common than 240. I'm guessing I'll need to find a way to drop it a bit to be sure? I think I've seen some VFD's that do lower output, but I'm thinking of getting a rotary phase converter instead, but not sure if you can lower the voltage with those? Maybe by intentionally under-filtering a bit with the run capacitors?
motor-wiring-jpg.389580
You have a delta-connected motor, which is less common in the US than a Wye-connected motor.
Assuming that the motor is wired for "higher voltage" and known to have been running from 440 3-phase, you should be OK rewiring it for "lower voltage" and running it from 240 VAC using either a VFD or a rotary phase converter. Here's a web page that explains delta-connected motors:
johnoder
Jul 16, 2004
Houston, TX USA
In case you have to have the chuck off bye and bye
My 24 is bigger but the same idea
pompeiisneaks
Aug 20, 2021
Thanks,
I noted on the current wiring that it's wired for the lower voltage so I think I'm good there (i.e. I could see wires 2,8,4 were wire nutted together) I'll triple check that before I put power to it. Glad to know it should be fine at 240 3-phase.
pompeiisneaks
Aug 20, 2021
That's really cool, I'm guessing that means otherwise you have to wait quite a while for the head to stop spinning before you can do other work...
the other thing I'm going to have to figure out is related to on/off state. The run/stop lever seems to have had something disconnected in the past. I have the lever there, but it attaches to a mechanism that seems like it expects a rod to go off towards the area near the bottom of the lathe spindle connection for the belt from the motor, and there's no rod there. I.e. it seems the lathe is 'on' right now, as I can turn the chuck or the large wheel at the back and they're linked, but not sure if it's in 'forwards' or 'reverse' Either way, I can't disable it as is. I'll have to possibly jury-rig something short term to enable me to adjust that.
~Phil
johnoder
Jul 16, 2004
Houston, TX USA
~Phil
You are referring to clutch linkage. Rod runs along in front so you can have (sometimes) a lever at HS end and another at right end of carriage. Left end of rod works a rod going back to the shaft and lever hanging out of the clutch housing.
Some of these had a reversing gear up in the head stock so additional things could happen with the clutch lever - like reverse the spindle, My 24 had that though disabled in the dim past
johnoder
Jul 16, 2004
Houston, TX USA
If you ever decide to snatch off cover this is what you will see - and it gives you an opportunity to replace the felts over the oil ports in the bearing caps on the spindle. Looks pretty sturdy in there. No oil pump yet on this 1923 version, just splash/sling-it-off .
pompeiisneaks
Aug 20, 2021
Oh my, that's too bad, I'm missing some of those parts... I'll get a photo here soon showing what I 'do' have but I don't know how I'll manage to fix it.
Thanks for the detailed photo. I realized you were linking different pages of that same document, so I went and downloaded all 59 pages and converted them from jpg images to a single PDF if you want me to attach it here?
~Phil
pompeiisneaks
Aug 20, 2021
Oh nice view. I do want to do that at some point but I'll need a cherry picker or gantry before I can lift of that behemoth of a motor on top to get a look at the guts. I do need to before I start her up, because there's a lot of old crusty oil build up everywhere I've looked. I'm going to have to come up with a strong degreaser that can break down uber long term aged goo that was once oil but now more like gum.
~Phil
johnoder
Jul 16, 2004
Houston, TX USA
~Phil
Good question on the pdf - I do know that some time back PM would only allow very "small" pdfs. Now if you can HOST that pdf and link to that - that would be great.
pompeiisneaks
Aug 20, 2021
Here are a few pics of the back side. I also have the other stuff that came with it. If people can point out 'what that is' I think I know a lot of it but still not against smarter people than me helping :D
Cal Haines
Sep 19, 2002
Tucson, AZ
... I realized you were linking different pages of that same document, so I went and downloaded all 59 pages and converted them from jpg images to a single PDF if you want me to attach it here?
~Phil
You might want to upload it to VintageMachinery. There's even an L&S page (link). The problem with hosting it yourself is that if/when your domain goes away the information gets lost.
johnoder
Jul 16, 2004
Houston, TX USA
There is tons more - if less comprehensive and more personal - just on the old L&S
