Hello and good morning all!
Not sure if it's necessary here, but as I'm new to the forum I wanted to post a quick hello to everyone
I've followed several threads here for years and have learned a lot of tips/tricks for small projects and what-not, and as I've decided to "upgrade" my tiny shop a little, I figured it was time to join up
I'd been on the hunt for some mini/micro machines for a little while now, looking for deals/used/etc and finally have a few in and am getting set up!
First off, I'm well aware that I shouldn't have high hopes for these Chinese machines, but due to shop size and budget constraints, this is what I'm working with for now
Drill Press: 10" WEN with digital speed readout
Mini Mill: HF 44991
Mini Lathe: Grizzly G8688
So far, I've got the drill press and mill all completely torn down, cleaned up, and all necessary hardware loctited and torqued
For the mill, I've polished the gibs and ways, and have already installed some upgrades from LMS (While I had it apart, I figured why not) including the air-spring and belt drive conversion
The lathe is sadly still in its shipping crate as I wanted to finish setting up the mill before opening a new project.
Aside from tramming the table, any other advice on getting the machine set up? Any MUST HAVE upgrades before I start?
As far as the Lathe goes, I'll be stripping that one down, cleaning and tightening as well. Same questions there... Anything I should replace right off the bat?
Again, I'm aware of the limitations of these machines. I'm mainly looking to expand my abilities and be able to make small parts, fixtures, tooling etc that I need as other projects arise.
Thanks for all of your info over the years, I look forward to working with yall
Mini Mill: HF 44991
