Nexus 700D-II parameters
Azoth
May 10, 2019
Houston, TX
Mazatrol Matrix Nexus controller on a Mazak Nexus 700D-II vmc using eia programs.
There are some behaviors I want changed that I'm hoping there's a parameter for. Have been trying to get them to buy the operator/programming manuals for the machine.
Bad behaviors:
Restart 2 nonmodal can be used to skip around in a running program on our Integrex, but it doesn't work on this Nexus. You can only choose the original point to restart at, but you can't skip down so right now I'm having to edit the program with GOTO if I want to skip down, and not forget to remove GOTO before the next part.
Hitting Reset also resets me to G0, G91, G54, and clears my supposedly modal Feedrate value. Would rather all of these remain modal.
Do you know if these can be corrected with parameters?
Azoth
May 10, 2019
Houston, TX
The maintenance guy found a .pdf of the parameters for me.
Found the parameter that let's you jump around in a program:
F168 Bit 6
[RESTART2NONMODAL] menu function during stop of an EIA program execution invalid/valid
Azoth
May 10, 2019
Houston, TX
F168 Bit 6
Can't edit my post. And the rest,
Modal at power-on or reset:
F93.2
0 = G91
1 = G90
F94.3
0 = G1
1 = G0
With reset key:
F95.7
0 = Coordinate system responding to G54
1 = Coordinate system unchanged
I'll have to post the link for the parameters/alarms .pdf in the manuals forum.
manual number H562HA0019E
