No one makes a small vertical metal cutting bandsaw
mrplasma
Sep 25, 2020
It seems that no one manufactures a small vertical metal cutting bandsaw. Yet little horizontal saws and vertical wood cutting saws flood the market. Many resort to fabricating a stand to hold their portable bandsaw in a vertical position.
I can't fit any more equipment in my garage, and I would have problems getting even a 14" metal cutting bandsaw into my basement. I mounted my Milwaukee portable saw in a stand, and while it works ok, you can't make more than about a 3" deep cut before the material hits the frame. Some people take steps to reduce the speeds of box store wood cutting bandsaws, but they still lack the rigidity for cutting steel.
The best I could do was to convert my 35 year old 4 x 6 import horizontal saw for vertical cutting. I never used it after I got my 7 x 12 saw. The little 4 x 6 does better as a vertical saw than it ever did in the horizontal position. I fabricated adaptors to take the twist out of the blade, giving it a 5" throat depth - not great, but a lot better than the portable saw. I swapped out the 1/3 hp import motor for a 3/4 hp Baldor.
Maybe someday someone will start making like a 10" vertical metal cutting saw.
BT Fabrication
Nov 3, 2019
Ontario Canada
View attachment 389298 View attachment 389297 View attachment 389299 View attachment 389300
define a small bandsaw?
really small is a portaband
medium small most 7x13 horizontal will go vertical.
larger ones with an 18" wheel do exist but are $5000+ like a dake or hydmech.
there are also roll in bandsaws
lazz
Feb 12, 2012
The warm desert of Phoenix Arizona
Today there are few affordable options. 50 or more years ago Rockwell made a very usable 14" horizontal bandsaw, Model 28-200. $1000 will buy and refurbish a saw in almost any condition.
Clive603
Aug 2, 2008
Sussex, England
The import 7 x 12 horizontal saws are generally reckoned to be head and shoulders above the 4 x 6 H-V breed. With reason industrial rated, if you don't expect a boy to do a mans work, rather than hobby rated as in needs fiddling, fettling and occasional swearing at.
Given that it ought not be too hard do a similar conversion using a 7 x 12 as a basis. The economics don't look too unreasonable compared to searching out an older saw that could be re-built. Obvious drop in quality compared to an older industrial machine but you can jus go and buy one. Used or new.
Clive
steve-l
Mar 2, 2012
Geilenkirchen, Germany
There is no substitute for a proper industrial rated DoAll contour saw or equivalent. Take care of them and they will last your lifetime. Yes they are awkward and they take up a lot of space, but you will not be satisfied with anything less......believe me! My solution to this space dilemma was to weld up a stout trolley like cradle for all my saws and drill press these trolleys only raise the height 1 inch. All the wheels swivel. This allows me to roll these machines in and out of the garage as I need. I also made heavy duty, weather proof covers so that they can remain outdoors in my driveway without suffering corrosion and deterioration. This solution gives me great flexibility.
lucky7
Sep 6, 2008
Canada
Agree with DoAll recommendation.
If the OP wants smaller than smallest DoAll, consider a made in Canada General. Up till about 2005 they made a 14” throat version of their wood cutting vertical saw with a fairly decent back gear. Reasonably solid for what it was. From recollection slow enough for low carbon steel. The General International rebadged Chinese stuff otoh was crap imo.
memphisjed
Jan 21, 2019
Memphis
Multiply by 10 for hydmech, marvels are 70 as of the first.
memphisjed
Jan 21, 2019
Memphis
So hypethetical, asking for a friend..
Would there be any reasonable market for a 14 inch wheel 1/2 inch blade contour saw?
14 inch wheel has very little wiggle room in option.
Would you spend 6 grand on one?
lr harner
Nov 10, 2014
littlestown PA
i love my roll in saw but thats bigger then you want. even if they could make one half the size at half the cost i dont think they would be a lot of buyers. i know a bunch of knife makers that woudl not be spending 2500$ on a small roll in saw but they should. they do all kinds of great work in a small shop. the only option i can think of woudl be to mod a 7" class saw and give it gravity feed
sfriedberg
Oct 14, 2010
Oregon, USA
Jet has a bunch of variations on the Delta/Rockwell14" vertical bandsaw. There's at least one (model J8201-K) with a two-speed gearbox, and the lower speed is suitable for cutting steel. This is a pretty light-duty saw, of course, but it's much better made than the generic 6x10 horizontal class.
Superbowl
Feb 12, 2020
It took me a year to track down a decent Powermatic 143 with a 14 inch throat at a reasonable price but it was worth the time and effort. The full size throat on a true vertical saw allows you to cleanly cut a decent sized piece of plate or sheet metal that is impossible to cut on a horizontal saw standing upright. In my case you can cut plate 14 inches wide on one side and infinitely wide on the other side. Plus on a true vertical the bed can be tilted, there is room for a cutting guide and a slot for a miter gauge.
Jan 15, 2005
The Netherlands
Over here you have the Mossner record 320 with a wheeldiam of 320mm Also has a build in butt welder for the saws and a grinding wheel to grind the weld So you can saw out big holes of any shape Very well build
Still available new But EXPENCIVE
Peter
DDoug
Oct 18, 2005
NW Pa
You can build a Roll-In saw in your garage with a buzzbox and a torch. Make it any size you like.
JFoley
Jan 28, 2023
I use a 30 year old 14" wood cutting bandsaw with a 3/4 HP variable speed DC motor. Maybe it's a little stiffer than the new ones but I cut anything I want on it with a nice Starrett blade. I added brushes to keep the wheels clean and cool blocks on the blade. Slow and steady does it with 304/316 SS, mild steel or aluminum. I'm just a hobbiest so I don't push on it all day long but it does what I need.
Blazemaster
Oct 13, 2009
Olympia, Wa
I have an old delta 16" that I added a gearbox to, to slow it down. Not as rigid as a do-all, but I have cut some 1" thick stainless and did just fine. Make a good push block, your fingers will get sore.
