gregormarwick
- Feb 7, 2007
- Aberdeen, UK
The ultimate end goal for now is to understand how to 2D draw a M thread. 1) basic profile (done) 2) add standard defined deviations/tols via dimensions (automated expressions in my case) - work in progress. So to gain understanding and an accurate representation (in CAD) of the true geometry I am dealing with.
For instance; here goes a true representation of a ISO965 M10X1.50 6g and the mating M10.1.50 6H. How would I go about machining this non-sense with a so called full-profile ISO 60deg insert with a tip radius of 0.22mm, or should I say how much deeper I need to dive that insert in that material to have it fully machined, or ruined.
Your Q: Why? I need validation, dims, compute on screen, a reliable method, linear analysis geometry, something/anything to ref about...
ISO 965-1 Section 11 discusses the root contour geometry. Easy enough to find a copy if you can't/don't want to buy it.
Go and download some insert models from Sandvik's website. Below is a link to their basic 1.5mm external full profile M insert. Look at the point geometry - you will see that it is not a radius but a flat with fillet radii to the flanks, as is laid out in said section of the standard.
Note that the min/max root radius (the flank-root flat fillet, not a full radius fillet) of an M10 6g/6H is .188/.216mm
Sandvik Coromant
