CommanderKeen
- May 10, 2022
I'm newish to machining, but I'm learning.
Here's the question: I'm tapping a bunch of 5/8-11 holes and having issues breaking tap teeth. Material is 1045 steel, using a 4 flute tap, lead drill is 35/64 with an 11/16 counter bore. They are blind holes. I blow the chips out thoroughly before tapping. And we hand apply cutting fluid before each hole, cleaning chips off the tap each time as well.
(We have the same issue with other sized holes as well)
Here's the question part: So on the first op,
G99 S100 F.0909 while threading
Second op (other side mirrored holes)
G98 S110 F10 while threading
Both run G84 for the cycle.
The second op cut way better than the first. Id like to know why? Of course I'm running an established program someone wrote a while ago.
Thank you for the help,
Keen
Keen
