No.......no no no....did I reach the minimum yet?
Sir
drill size 0.4375+0.0005= 0.438" instead of 0.4375"
But i think it's not possible since the tolerance in NPT thread very tight, want to make sure
Errr?
No it's not. NPT is a tapered thread, so even if you could make a "perfect" drill hole, it would only be "perfect" at one depth.
Regards.
Mike
Sir
I hate pipe threads and in my previous job I worked at eliminating them as they are the #1 source of leaks. Got rid of about 90% and virtually eliminated all leaks. The reason it is so hard to seal them is that the peak of the external thread doesn’t completely seat in the root of the internal thread and viceversa. So you get a spiral leak path that just drips. O-ring, taper to taper, victaulic, Banjo flange, bolted flange, all are much better.
Hi
Would like to try to drill NPT drill without reamer, so the drill size for 1/4 - 18 is 7/16 = 0.4375 what if i use 0.438 drill so +.0005 .. is there going any problem?
Thnaks...
Tapped NPTs tend to leak where the flutes stopped.
I'm curious, was most of the leaks in heat treated blocks?I hate pipe threads and in my previous job I worked at eliminating them as they are the #1 source of leaks. Got rid of about 90% and virtually eliminated all leaks. The reason it is so hard to seal them is that the peak of the external thread doesn’t completely seat in the root of the internal thread and viceversa. So you get a spiral leak path that just drips. O-ring, taper to taper, victaulic, Banjo flange, bolted flange, all are much better.
Notice
