NPT thread dimensions calculations
M Code
Apr 4, 2021
Hello,
For Understanding of NPT thread
I am using NPT Thread Calculator to calculate the NPT thread dimensions.
But I am confused
For example ¼ NPT thread
Drill size is 7/16” but how long is deep?
Thread Size is ¼ with 18 TPI but what is the total depth of the thread?
My understanding for example ¼ NPT will include
NPT total depth = Hand Tight Threads + Wrench Tight Thread
= 0.2278 + 0.1667 = 0.3945
If total depth = 0.3945
Drill 7/16” depth can be 0.6945” for clearance only (flexible)
Is this the way to calculate NPT machining dimension?
The value 0.2278 will be inspected using the plug gauge?
Thanks,
M Code
Apr 4, 2021
Thank you so much, in this for 1/4 - 18 thread starting point generated as Z-0.3945.
However, before thread what is the depth of drilling operation?
What about the chamfer or thread relief is it going to be counted from the threads turn or no? in other word during inspection the flush from the chamfer or after the chamfer?
What is the depth and angle of the chamfer?
Thanks sir
Booze Daily
Sep 18, 2015
Ohio
Well, you're going to need to drill deeper than .3945.
Flat on the gage should be flush to face +/- 1/2 turn.
Caliper across the gage at the dia of the flat. Your chamfer needs to be bigger than that. 45 deg typically.
GENERALDISARRAY
Jan 3, 2019
Measure the cutting length on the threadmill you are using. That is my cut depth for the threadmill. The drill depth obviously needs to be greater than that.
As per the asme b1.20.1-2013 the gaging point is the point of last thread scratch on the chamfer. Where the chamfer exceeds the major of the thread. Try to keep your chamfer theo as close as possible to the major as you can. Since most people expect the gage flat to be flush with the end of the part. Regardless of chamfer. The chamfer angle is not covered in the spec that I see. I use a 90 deg included spot tool.
Dont forget
Pipe threads are for plumbers,
M Code
Apr 4, 2021
Dont forget
Thank you sir.
So I understand:
1- not all the chamfer length is included in gauging, only after the first thread appear on the chamfer, gauging point will start
2- chamfer 45 Deg. can be 0.04" per side (thread height) in case of 1/4 - 18
the cutting length of the tool is 0.598" but in the case of 1/4-18 what if machining 0.3945" deep as per tables (L1+L3)... does the tool need to fit for all the cutting length to perform the (Hand-tight Length)??
M Code
Apr 4, 2021
Chamfer Deg. is 45
Length of the chamfer can be the thread height?
Booze Daily
Sep 18, 2015
Ohio
Chamfer Deg. is 45
Yes.
Tool only needs to go .394 deep. You can use comp to get the gage to fit.
The extra length is because that thread mill can also cut 3/8 NPT which has a longer length of engagement.
You are probably overthinking this. Just make the gage fit and make it look pretty.
M Code
Apr 4, 2021
Yes.
What if the tool go deep more than .394 like 0.53
is that going to be ok for 1/4 NPT? since the gauge is fit with hand-tight lenght
LKeithR
Sep 1, 2011
Langley, B.C.
...You are probably overthinking this. Just make the gage fit and make it look pretty...
I would think that it would be easy to make a couple test pieces and adjust from there. I'm strictly
manual so I don't thread mill but when I tap pipe threads the drill goes in all the way or right through
the part. No consideration given to the drill depth. Would it be different if you're thread milling?
mjk
Oct 20, 2005
Wilmington DE USA
re drill depth
if its an NPT or any pipe thread, pretty good chance its drilled to cavity depth of the area where the (liquid or gas) is contained
Rarely will you see a blind pipe thread unless its a special application for a future access connection
