EPAIII
- Nov 23, 2003
- Beaumont, TX, USA
Probably like most people here, my shop is primarily a machine shop. But I do make wood projects from time to time: my latest was an exercise bench for my wife. And, of course, some wood parts as needed. Also my shop is a two car garage that is packed to the overflow point. Not much room for the wood tools. I do have a small table saw and I will probably be keeping it: it makes a good table for other projects when I am not cutting wood parts with it.
For years I used a straight piece of lumber to guide my circular saw and that worked fairly well. I was able to get straight and square cuts. But about 8 or 10 years ago I decided I needed better dust control to keep it off my tools and out of the open bins that I used for most of my shop storage. So I started looking for a circular saw with good dust gathering ability - in other words, a vacuum port. And, as always, I was looking to pinch the pennies.
What I found was the Grizzly track saw. It had an enclosed blade with a vacuum port. At the time they had a starter kit with the saw, a blade, and one length of track which was a bit over four feet long. So I got it along with a second section of track so I could rip an eight foot length (plywood). I also got one of those automatic relays that starts the vacuum when the saw starts and keeps it running for about 10 seconds after the saw quits and an extension hose for the shop vac. I also got a premium Freud Diablo blade. Overall this was not cheap, but still about half the price of most other track saws.
I was delighted with this combination. With the clamps that fit on the bottom of the track, I could set up the cuts in less than half the time that the straight edge method took. In some cases I can even just lay the track on the wood and the foam strips will hold it well enough for a cut. The cuts are all but perfect. I do score the wood or apply tape before making a cross cut. There is almost zero dust to contend with. I have since purchased a third, shorter section of track for cross cuts and I find that the track sections will assemble together perfectly straight (by woodworking standards at least).
For the occasional wood project, the track saw, along with a table saw is, to my mind, a perfect combination of tools. And they take up very little space in my crowded shop.
