I need to make some steering pins and bushings for an old obsolete Gradall 534B. Replacement parts are not available. This will be the last repair to the steering. Anything done will last longer than the rest of the machine.
The pins look to be standard sizes, 1" to 1.5" diameters. Figure I'll cut them from 4140 or 4130 bar stock (the owner wants cold rolled
...) They will only need some grease holes/groves and a couple need a grove at one end for the retention plates.
If the housings are damaged they plan to just weld in the bushings, there will be no line boring
What material would you use for the bushings?
