Hi Tinhsoftware:
You will never get there single point threading C101 or C110 copper because the chip is trapped in between the flanks of the thread as it's being created, so it trashes the developing thread, especially at the crest.
You have two choices:
1) Change the grade of copper to C145 tellurium copper (it's free machining and will break into small chips)
2) Change your process from single point turning to thread milling, thread whirling or thread rolling.
Thread rolling is best (if you don't need to care about how the thread crest looks) because there is no chip at all but the crest is folded over on itself.
Thread milling and thread whirling are better than single pointing because the chips are discontinuous and can fall free more easily without scarring the thread flanks.
Also, you can support the skinny thread crest with the material you haven't cut yet which you cannot do when single pointing.
Last you can try different lubricants...some have advocated buttermilk for machining copper.
Just be prepared to accept the smell when it goes rancid!
Cheers
Marcus
Implant Mechanix • Design & Innovation > HOME
Vancouver Wire EDM -- Wire EDM Machining
