SeymourDumore
- Aug 2, 2005
- CT
Hello Semore,
And repeatedly again, my better judgement was correct ...
Hello Semore,
To the OP: If you're using the start hole to pickup the part, are you sure the hole is on location? A lot of times wire start holes are just drilled and you will need to pickup the outside of the part, if you plan on using a hole for pickup it needs to be a bit more accurate, at least qualified/reamed or finished nicely with an endmill.
Your picture shows a wire block with several parts nested, are you cutting the center hole as well as the outside of the parts?
Is the hole you cut straight after you have wired it?
For a single part you could try picking up the part using your current method and then using the wire take some measurements around the outside of the part to see what you find, if part is picked up on center you should see equal numbers on opposite sides.
As far as picking up parts within .0001" on a wire edm it can be tricky. Since you're using the wire itself to pickup the part, you have variables of wire tension/deflection, the diameter of the wire, conductivity of the pickup face of the part to the table etc so it's not as easy as you might think. Silly things like a sharp corner shaving the wire slightly, or an oily surface giving bad contact can really screw you up.
Within a .0005" is no big deal, but the last couple tenths are not as easy as you might think. My favorite trick for this is to use several tooling holes, if you can use 2 or even better 4 tooling holes you can center and align between them and it helps to reduce some of the variables.
We have also found that if you have a ground diameter that absolutely needs to run dead nuts true within a .0001" to a wired feature it's not a bad idea to leave some material to finish grind after the wire work is done. but ymmv
Considering the start hole is .190 I'm guessing they aren't exact lol.
When I make a hole for edm pickup it's drilled and reamed so I can get the most accurate pickup, especially if I am burning multiple pieces. The thread holes are just drilled, they don't matter it's just to get the wire threaded...unless you drill the hole too close to the cut and you mark the part lol.
I always lay my thread holes out in cam and use lead in to get to the cut. It's fool proof. If I know there's a risk for a part or piece to drop and cause a shift I put the x,y0 somewhere not getting cut and leave enough to indicate straight (where the original indication was taken).
Wire edm has a lot of tricks and nuances. I've been doing it for a number of years and I know I don't know everything...like taper cuts, I really haven't done many so I'm not as confident. A lot of it is knowing your machine, what it can do, how it does it, and why.
I am picking up the start hole not the hole in center. The hole in the center isn't touched by me at all in the whole process. The center hole is getting a rod screwed in on it and then fitted to a plastic ejector mold.Reread this, are you picking up on the start hole or the hole in the center of the part?
I completely agree with you on this I shouldn't be having problems locating to .0001 of a feature, WEDM is fascinatingly accurate and there is no excuse for being .040 off a part. First thing I did after that part came out like that is giving the machine a good wipe down along with a wire alignment and taper-z alignment. As for crashing it I haven't personally crashed it since I got here two months ago(fingers crossed I didn't just jinx myself) but that's not to say that our previous WEDM guy didn't crash it all. At my current state of knowledge I would definitely say I'm not made for the "cut" but that is exactly why I'm on here asking you guys for help and why I've spent plenty of time scouring this forum and other articles for more information. I enjoy WEDM and so I'm going to keep going one step at a time until I figure it out.If your wire EDM is made within the last 25 years and you cannot reliably locate within .0001 to a feature, then you better give it a good cleaning, you've crashed it a few times or you're just ain't made for the cut! ( pun intended )
Do you have any good articles on this subject I haven't read about this yet. Otherwise I'm sure I could find some info with a basic google search.You especially need to figure out your overburn in the material first and foremost.
I checked the holes with the wire early on after someone suggested the same thing earlier in this post, I did pick ups on them with the wire and then rotating the wire 45 degrees and running it again to make sure the holes were within a tenth. Regarding actual position in terms with the program I will double check. The hole in the center of the part is not being cut just the outside.To the OP: If you're using the start hole to pickup the part, are you sure the hole is on location?
Thank you for the tip! I will definitely try this out on my next available job.My favorite trick for this is to use several tooling holes, if you can use 2 or even better 4 tooling holes you can center and align between them and it helps to reduce some of the variables.
Was just in conversation with them this morning and they are looking into it as well hopefully we'll get to the bottom of this today.Probably worth talking to whoever made up the block to find out what the plan was.
I apologize if I got this wrong but the hole is still there... it just now has a .012 line going up to where the wire burned up to the part. I'm pretty sure it can still be used as a way check what went wrong or as reference geometry. Though I might be totally wrong saying that I don't really have the experience to know if its now really screwed up.Yeah, don't wire away your reference geometry. That's the OP's problem, they can't tell who screwed up.
SeymourDumore- I can post the code however it is not short in slightest when outputted it gave me over 7,000 lines for all 8 parts. It feels the need to show every slight movement in x,y as a line. Lmk if you still want to see it.
That's about 100x as many lines as I'd expect for that part in a mill, but I've never run an edm.
Curious to see if that's norm.
Programmed via Mazatrol
If those shapes are just rectangles with rounded corners, then I would say something is DEFINITELY wrong with the code!
Looks like you're just doing a one-cut, no skims ( unless I missed something on your image ), so the code should be no more than say 40 lines max for each instance, including wire cuts, threads
ramps and all...
I am doing 1 rough cut 3 skims and then a cut off. It looks like each ID insert has about 830 lines of code but about 800 of them or just slight changes in x,y and u,v.
I'll post some of the beginning of the code below this:
L1
H01 = 0.01120
H02 = 0.00805
H03 = 0.00665
H04 = 0.00615
G62 X0 Y0
G97 X0
G70
G90G92X0Y0
M21
G00 X-.10000 Y.10000
M20
M122 M78
M78
(ROUGH PRIMARY CUT)
Z1=0
Z2=0
Z5=0.57021
E1411 F.236 M90
M80
M82
M84
G92 X-.10000 Y.10000
G41 G01 X-.19095 Y-.19133 U-.04989 V-.04988 H01
X-.18414 Y-.19836 U.00001 V-.00001
X-.17754 Y-.20561 U-.00001 V.00001
X-.17118 Y-.21305 U0 V-.00001
It does a whole bunch of these^ until it gets to the next cut. Hope this gives some insight on why my code is so long.
That's kind of weird that the code is so long but I'm not sure if it really means anything. Esprit might be outputting points instead of arcs which will make the code a lot longer, but it should be fine.
The weirder thing is all the small U and V moves, does your machine use a probe to align the workplane to the to surface of the workpiece? If so it might just mean the top of your workpiece is ever so slightly out of parallel with the table of the machine.
And goodluck with your next attempt, let us know how it works out!
The U and V movements are their because the ID insert has a 5 degree angle all the way around it. Normally when I'm doing just a normal 2-d cut those small U and V movements are not there.
Notice
