OffTopic~ Moving a big block of stone
My employer is having some new railroad track laid. There is a contractor out there doing lots of dirt work. Was out there snooping in the brush and found a bunch of these big blocks of cut limestone along the right of way. From some early railroad installation... not from a bridge abutment or culvert.... no streams close. Not sure what they were for.
I got to thinking~ One of them would sure look good in my yard. Maybe make a mailbox holder out of one
So, my maintenance of way contact spoke to the trackhoe operator and he said he'd pick them up and load them on our trucks, no problem.
Well, the first one he brought out was broken... about 1/3rd of it had broke off, but laying in the brush it looked all together. He brings it up and proceeds to gently let it out of the bucket and lay it on the bed of my old 1962 1 ton Dodge. I didn't see it was two pieces til it was too late.
First thing that happens is the small piece slides out and plops right down on the bed. The big piece, however, tumbles out over the hump created by the bucket teeth and proceeds to flip over and roll off the side of the truck and land on the ground
. That about mashed the springs and everything else flat. THAT IS ONE BIG BLOCK OF STONE! It's about 4 foot square and 32" thick.
So, the operator gently scoops the block back up and this time places it right on the bed.
Truck is wayyyy down on the overloads. I was a little dissatisfied with having a broken block of stone. But, there was more to load on the other guys 1 ton Chevy... a newer model. So, they told me to get out of the way so he could load his TWO blocks.
I think the two he picked were just one big block that happened to be split exactly in half. Anyhow, he got his truck in place and the skilled operator scooped up those 2.
I asked what size that bucket was classified as... 4 yard is what I think he said. It's a monster. So, he got those loaded on the Chevy.
I got to thinking that I may have bit off more than I could chew. Number one, the block is a MONSTER and I actually would have no way to move the thing once it dropped on the ground. Number 2, it was broken and that was unsuitable. I went down and pointed out one of the smaller blocks and told him I'd like to dump what I had and have him pick that smaller one out and load it for me, instead. He agreed.
Here it is sliding off the bed. There is a video, but it is lost in cyberspace. Tried to get it to youtube so I could link to it, but no luck. It's lost out there.
Those springs raised up probably 6 inches when that block slid off! If you look at the back of this side of the bed, you can see how the edge is bent over. That's a 10 gauge steel lip about 5 inches tall. The sides of the bed stick up that far and the wood sides that are usually on there rest atop that lip... keeps sand and gravel from getting out from under the sides. It smashed that steel right over when the block slid off when he first loaded it.
So, he scooped the broken block parts up and dumped them over to the side and fetched the smaller one and loaded it for me. It's 42" x 32" x about 25" thick. I can probably manhandle that block.
