Truckingmeister
- Dec 24, 2020
- Sheboygan Falls
I picked up a Kearney and Trecker model 1B Universal Horizontal Mill.
The issues I am having and yes I have looked on the internet quite a bit are I cannot find and owners or shop manual for this machine. The friend I got the equipment from had a fire and the information and maint logs went up in smoke. The bigger issue is, according to what I have found is this machine should have a B&S #10 taper. When I measure one of the shafts it was close, not perfect but I was using my veriers and not a micrometer, but never had much of an issue before with that method. I have 1.0555 vs 1.0447 on the small end and 1.298 vs 1.2597 on the large end. I ordered a 310 taper to ER32 collet adapter so I could fix my South Bend Lathe's apron ( I also got from the same person), well it dosn't fit, sloppy as heck. So crap now what?
That adapter measurements are as follows 1.003 small end and 1.2540 on the large end. So there is a little issue there too but I figured it still should work according to the standard spec's of the #10 B&S taper.
It is very hard to find information on this model, is it a rare one or just strange?
Thank you , hopefully I didn't ramble on too much. I also need to find a motor for it but I can save that one for later.
