For the headstock , when you
pull off the big cast cover over the belts
on the LH of the machine,you'll see (hopefully) a piece of pipe sticking straight out with a screw-on pipe plug. This is the headstock drain. You will have three
oil points to fill on the headstock. One for the rear main bearing, another for the front
main bearings. and another for the headstock sump. The front and rear have little screw oil ports over their respective sight glasses
on the operator side. The main sump fills through a oil plug on the top headstock cover. It even says "oil" on it.
As you go back to the LH end, under the headstock drain pipe, there will be 3 oil
drain/fillers for the gearbox. These come out of the gearbox, with the lowest one, the drain, a pipe with a plug on it like the headstock drain. Right above it, a pretty brass "GITS" (I think) Right angle oil level/filler and to the left a oil pipe with a 90 union and a plug. You will fill the gearbox thru the Gits Filler until level is reached thru the sightglass. And fill the 90
union till it won't accept any more oil. If you have a back gear( its on the belt end on the motor) it has its own little sightglass
and fills thru the top pipe plug. Thats a vented plug by the way. It drains thru a plug on the bottom, can't miss it.
The apron fills thru a screw-on filler plug on the front of the apron, about 1:00 to the handwheel. Drains on the LH side low with a pipe plug, Fill by sightglass.
Tailstock has oil filler screws as well as the electric leadscrew/reverse switchbox.
I am sure I left something out or if I'am
in error, You guys out there please correct me.I hope this helps. Daryl
