I work for an Okamoto factory authorized dealer. We sell new & used Okamoto I.D., O.D. & surface grinders as well as factory spec rebuilds. I personally scrape, build, install, troubleshoot, service, rig/ deliver & train operators. I have been working on Okamoto machine tools for ~15 years. Ask me anything
I work for a company that does OD and ID grinding, we also use Okamotos to grind the height. I’ll first put the part on and do a rough grind and try to leave .007 for the finish grind when I flip the part. But I’ve noticed I have to put in at least .0003 smaller number than what I measure after the rough pass, because it will take more than what you enter for it to take off. Also if I place the parts toward the end of the magnetic chuck, one side will be shorter than the other. Very frustratingI work for an Okamoto factory authorized dealer. We sell new & used Okamoto I.D., O.D. & surface grinders as well as factory spec rebuilds. I personally scrape, build, install, troubleshoot, service, rig/ deliver & train operators. I have been working on Okamoto machine tools for ~15 years. Ask me anything
It seems the OP has abandoned us.
OK. so, whyy won't Okamoto sell me spindle for my 6-18 linear/ newbe crashed cause he forgot the mag and raked the dresser block into the wheel. long /short, the taper mount runs out .0005 at the extreme small end.I work for an Okamoto factory authorized dealer. We sell new & used Okamoto I.D., O.D. & surface grinders as well as factory spec rebuilds. I personally scrape, build, install, troubleshoot, service, rig/ deliver & train operators. I have been working on Okamoto machine tools for ~15 years. Ask me anything
Hi Tbone ,Doozer- I recommend flushing your machine with Mobisol. This is added to your hyd/ way oil at a small percentage and run for about 8-12 hours. Do not run longer or you risk damage to hydraulic seals. At the very least, use a squeegee and lint free towels to wipe inside of reservoir clean. No need to soak with kerosene. Just be sure no coolant contamination is present.
Remove & inspect oil filter. I recommend replacing but at very least, clean in parts wash & blow off until dry. You should be able to see light clean through the inside of filter.
Fill machine with recommended mobile vaculine 1405 or vactra #1. (Must be a hydraulic/ way lube oil at 32vg)
As for the table issue, this could be several things
-valve body
-DX4B control or hydraulic control board
Table proximity switches
(failed or just dirty/blocked)
-terry valve adjustment
-leaking/damaged cylinder rod seals
-failed table directional switch
-sticky solenoids/ failed coils
(Although new, soiled oil will gum up new solenoids within days or hours)
-coils installed in wrong positions
Please let me know what control your machine has (DX4B or FX control) and I can narrow this down. Worst case give me serial #.
If the machine has a DX4B, the front panel of this control will display all I/O signals & alarms via red/ green LEDs. If so, tell me what # red LEDs you have.
A step further, if you are the DIY type, I can provide you a flow chart style trouble shooting guide.
Hope this helps, let me know what you find. There is more to check on the vertical after this is resolved.
Notice
