OKUMA canned cycle
weav6385
Mar 14, 2023
we have an Okuma lathe here with an OSP7000L controller. We normally longhand everything or use cam software. Trying to figure out canned cycles here. I have the format just how it says and even how i have seen other people here post it. The problem is, on the OD cycle im trying to leave .006 on the faces (W value, W.006) the cycle runs however, it is taking an additional .006 on the faces instead of leaving it!!! What the hell?? These Okumas are so different in some ways from Fanuc it drives me crazy. It has to be something stupid. Maybe a parameter? I dont know. Not using comp either. Thanks for any help.
G0 X3.0 Z.1
G85 N123 U.01 W.006 D.060 F.019
N123 G81
G0 X2.0
G1 Z0 F0.01
X2.5 Z-0.25
Z-2.0
X2.75
Z-2.5
X3.0
Z-3.0
G80
G87 N123
When using a turning cycle on bar stock, the OSP "usually" would like to see it something like this:
Example = 4." bar stock, 2.5" long. Turning a 2." hub.
NLAP1 G81
G0 X2.
G1Z-1.
X3.875
Z-1.5
X4.
G80
G0X20.Z20.
G96 X4. Z.15 F.01 S800 T0101 M3 M8 M42 M86
N10 G85 NLAP1 D.125 U.01 W.005
G0 X20. Z20. M5 M9
M2
NLAP1 G81
G0 X2.
G1Z-1.
X3.875
Z-1.5
X4.
G80
G0X20.Z20.
G0 X20. Z20. M5 M9
M2
I actually do it backwards from you .
NLAP1 G81
G0 X2.
G1Z-1.
X3.875
Z-1.5
X4.
G80
G0X20.Z20.
G0 X20. Z20. M5 M9
M2
The way I would generally do mine for a simple single depth LAP. I have never done it the way you showed. Does it pretty much work the same way? I have much more FANUC experience than OSP.
NLAP1 G81
G0 X2.
G1Z-1.
X3.875
Z-1.5
X4.
G80
G0X20.Z20.
G0 X20. Z20. M5 M9
M2
It works quite well.
Here is a snippet of a boring lap routine. (this is for OPS2000)
G0 X20. Z10.
M01
G95
T111111 (PICCO BB)
G00 G99 G97 S1500 M03
G00 X.45 Z0.5
M08
G85 NAT02 D0.1 U0.02 W0.005 F0.015
G87 NAT02
NAT02 G81
G00 X.707
G01 Z0. G41 F.005
X.583 Z-0.062
X.535 Z-.9
X.485 Z-.925
G00 Z.1 G40
M09
G80
G00 Z1.
G00 X20. Z10.
The rough tool is set conventionally, with Z0 at the front.
The "T0101" on cutting conditions line calls up the tool and offset.
If i were using cutter comp, it would read "T010101"
Correct, but if a different tool is establishing Z0 and his shoulders are too deep, it may be a slight Z0 offset adjustment on the facing tool to give correct shoulder depths.
He didn't say whether he checked the should depth after roughing but before finishing.
Are you measuring the depths from the front of the part(Z0)? I don't see a facing pass in here anywhere done at Z0 to establish anything. I think booze may be on the right track where your facing tool and this tool may just not be taught correctly to one another. Also if you run everything you posted, there won't be any material left behind for finishing after the G87 runs.
g87 is the finish pass g85 is the rough
