okuma lathe lc20
JLAUCIUS
Apr 13, 2021
i put a collet on my okuma lathe ,once a close the chuck the machine saying the chuck is open for some reasons.
i dont know what going on.
JLAUCIUS
Apr 13, 2021
i already had the switches where they suppose to be.i still not getting the green light on.thank u
JLAUCIUS
Apr 13, 2021
is there any setting need to be change when you take off the chuck and replace it with a collet?
thank you
Mtndew
Jun 7, 2012
Michigan
Does the machine need to be set to ID chucking when you put that collet on?
Is it a dead length collet or a pull style collet?
mottrhed
Sep 23, 2013
nh
Bench test the prox sensors for functionality, then test in place, if ok chase the wires to the control.
angelw
Sep 10, 2010
Victoria Australia
Typically, Collet Chucks work in the reverse to a conventional Chuck. Accordingly, the open direction of the Draw Tube for the Three Jaw Chuck, is the closed direction for the Collet Chuck. There will be either a Hardware or Software switch to change the chuck gripping close state from External to Internal. The control needs to be set for Internal Gripping for a closed state for the Standard Chuck, to satisfy a closed state for External Gripping for the Collet Chuck.
Sorry Mtndew, I didn't mean to cut across your answer; I was still typing when you made your Post.
Regards,
Bill
Voss Machine
Sep 9, 2013
Minnesota
The parameter for OD or ID chucking needs to be changed depending on whether or not the collet nose is a "pullback" type which will have the parameter set to OD (or 0). If the collet nose is a true length (dead length or push type) then the parameter will be set to ID chucking (or 1).
This info is for an Okuma LNC8 with a 5020L control.
bradleyk
May 6, 2005
Ohio
You should have a switch on the control panel for ID or OD chucking (you'll need the key for this). Just turn the key. On my older LC20 with 5000L control, it's on the lower right side next to the "CONTROL OFF" button. The 5000L-G control may be in a different spot.
DouglasJRizzo
Jun 7, 2011
Ramsey, NJ.
On my lathe I had to reverse chucking direction to get the machine to clamp a collet properly.
On the OSP-5000 there's a key lock on the panel, indicating direction. Some older Okuma lathes have a two way valve near the pressure adjuster.
