I would guess that getting Zeiss to make a custom lens is at least four figures. I'm strictly looking at off the shelf.Of course, you could just run down to Oberkochen, and let Zeiss make up you a replacement. I'm sure they would be glad to help. .
I have yet to fix my davidson d638 but i did find out for relative certainty that the reticle does not need to be at the focal point of the objective lens.Hi John, thank you, I was hoping you would weigh in. You have lots of real-world experience, and I am a rank beginner with none of that.
Edmund doesn't have suitable lenses in diameters > 25.4mm. Also, in that diameter, they only have focal lengths of 250 and 300mm, not 275mm.
Ross Optical has a lens that looks quite close, part number L-AOC222. This has a diameter of 38.1mm (about 1.1mm too large) and a focal length of 280mm (5.7mm too long). The 1.1mm larger diameter can be accommodated with a modified lens carrier, and the extra 5.5mm of focal length is within the range of the focusing mechanism. So I may go this route.
John, could you tell me your opinion regarding the beamsplitter quality? Can I use a "normal" off-the-shelf 50/50 silvered mirror? Or do I need to get a beamsplitter that is flat to 2 x lambda or lambda/4 or parallel to that amount?
In the instrument, the beamsplitter holder consists of a machined (not ground) brass 45-degree surface, with two bronze-copper spring clips to hold the beamsplitter against that. It looks as if the beamsplitter is 1-2mm thick. So not a holder that would maintain a surface to lambda/4 from what I can see.
Cheers,
Bruce
PS: if you don't understand my question about beamsplitters, I can give links to some different models and their specs. There is a range of flatness available from unspecified to 6 x lambda to lambda/10. These are typically "per inch". It is not clear to me how flatness errors in the beam splitter propagate to angle errors in measurements.
[EDIT] I talked this through with a couple of colleagues who know more about optics than I do. The conclusion is that even a "bad" (meaning: not flat) beamsplitter is OK. Here is the argument:
The purpose of the beamsplitter is to illuminate the crosshairs. But the crosshairs are sitting exactly in the focal plane of the objective. So any light rays that leave the crosshairs and enter the objective will be correctly collimated at infinity. It does not matter how those light rays reached the crosshairs, or in what direction. The only potential effect of a "bad" beamsplitter is that it will waste some light that will go in the wrong direction and not make it to the objective. But this is not enough light to affect the function, and having the "wrong angle" on the illumination rays does not matter, since the crosshairs sit in the focal plane.
Ha, I couldn't imagine what Zeiss would charge for a single one off, if they would even do it, now maybe for 1000 pcs. they might talk to you. Actually, I don't know if this is correct, but I think...think that most of their production glass (and just about everybody else's) is now made in China.I would guess that getting Zeiss to make a custom lens is at least four figures. I'm strictly looking at off the shelf.
That's why I'm going to diamond wheel it on my cylindrical grinder, if the local opticians shop won't take it on.IME fine diamond wheels on surface grinders leave much nicer edges than plated hole saws on mills, though I’ve only used really cheap hole saws.
I guess the optician option depends on what they charge.
Notice
