On Fanuc "i" controls, how long will parameters stay with battery disconnected ?
21iT, proceedure for changing CPU battery is to run control for 30 seconds, shut it down and then change the battery. According to Fanuc literature you have 30 minutes to do this before you might loose parameters.
First off, I'm curious why they recommend shutting the system off in the first place....why not just change the battery while the control is still running like in the old days ?
But secondly, I'm curious is 30 minutes being conservative, or pretty much right to the minute ? I ask this because I'd like to inspect some boards behind the yellow plastic case but the only way to do this is remove the yellow case but when you remove that case you also are removing the backup battery ! I hate the thought of having to reload parameters just to reseat some boards...seems ridiculous. Then again reseating a certain board I might loose parameters anyway...not sure which one they reside on. Thoughts ?
