Nemesis
- Nov 7, 2015
- Southwest, MN
Looking for some operating advice/feedback on propane stand-up forklifts. I just bought a Clearr LSU-30 forklift which looks similar to a Namco. Now that I have finished fully servicing it, fixing the brake pedal, battery tie-down, etc. I have been using it. This thing is awesome to have around, but the mechanics of driving it feel a little off so I was hoping to hear from others. The Clearr has a dead man brake on the left side and an accelerator peddle on the right as seen here:
The brakes are fully engaged when there is no weight on the peddle and the peddle is in the air. When you stand on the brake peddle/platform it releases the master cylinder and brakes allowing the forklift to roll extremely easily. Because of the fact that you put your entire foot on this large peddle and stand on it, I don't feel like it was intended to be used as a brake during maneuvering, only as a parking brake. But maybe I am wrong on that assumption.
The gas peddle is designed for you to stand on as well rocking your foot forward to speed up the engine. There is very little movement from idle to wide open.
The forklift is 100% hydrostatic with forward and reverse simply being a hydraulic lever in the dash. Now where the weirdness comes in is that every other hydrostatic that I own provides resistance to rolling when not being driven forward or reverse. This forklift does not. When in the neutral position the forklift is allowed to fully free wheel. It starts rolling if you breathe too hard.
My question is whether or not this is how other forklifts like this operate? Because of the way the brake is set up, I don't believe you use it as a brake. This means that I have been slowing it down on slopes or when I am moving forward by reversing the hydrostat. Because of how easily this one rolls, maneuvering in tight places is pretty touchy as you are playing with the hydrostat back and forth in forward and reverse to keep it in one spot or make fine movements. If I try to use the brake as an actual brake that is also awkward because you are trying to rock back with your right foot to slow the engine down while at the same time lifting your left foot in the air.
Again, just looking for other's experiences. Do I just have a learning curve here or could something be up in the hydraulic valve that is not slowing/holding motion when the hydrostat lever is in the neutral position? This one did have a side shift added after the fact which means they added another node onto the hydraulic valve body. Not sure if something with that installation could have caused it. Thank you for your help!
