Options for a simple DRO on a tables saw
KT_NorCal
Jun 16, 2022
Hi There,
I've got a 1979 Wadkin Bursgreen AGS10 table saw that I'm trying to finish up restoring and one of the things I would like to do is add a simple DRO to it. The kicker is it has a fantastic fence, but the basic table saw focused DRO set-ups out there won't really work with it given how it works. My goal has been to find some sort of magnetic tape based (simple) DRO that would allow me to do a custom install on the fence. For this it sort of needs three basic features:
1. has a small-ish remote reader (or remote display depending on how you look at it) that allows the display to be mounted onto the top of the fence separate from the reader (wire connection is fine).
2. The display/reader would need an option to be battery powered (DC connection could work... would just be a hassle).
3. The reader would need to be able to read off of a magnetic strip it was either in contact with or a few mm of.
It would be nice if it had the ability to set a zero by running a board through and then inputing a direct measurement. Proscale does this and iGauging does as well (I think).
Anyway, I've searched around and only found:
1. Wixey
2. Pro-scale
3. iGauging
I would be interested to hear if anyone has done something similar and/or if you have heard of any other options. Of the three iGauging seems to have the most possibility, but is still not ideal so just looking for ideas!
Thank you!
KT_NorCal
Jun 16, 2022
These guys are one of the best in terms of product quality.
Yup, pretty familiar with Renishaw... definitely a bit much for this sort of thing I'm guessing given I only need accuracy in some level of fractions. Plus would still have to find a electronic display/reader for it!
Did find these in further research today:
stoneaxe
Mar 2, 2010
pacific northwest
I looked into this one time- delta did have a mag tape and reader for a saw years ago-
I bought one but never put it on- ended up giving it to a friend.
Is this just for general purpose or is there a specific reason for the DRO?
KT_NorCal
Jun 16, 2022
General purpose. The fence is great... very rigid and set up in a way that integrating a DRO into it might work well if I can find the right bits.
Also, frankly is an interesting challenge that would be useful to have on the saw.
wood2steel
May 17, 2013
georgia
KT, I can see the interest stirred with the idea for the table saw. I did the same some 30 yrs ago, but finally realized the fine dust especially high rosin content woods, would eventually lead to issues with the readers. As Dan said, the Biesemeyer has served us well! I have used iGauging units on the big Powermatic planers here for yrs with good success, but you're only dealing with large wood chips on these machines and not the powder dust. Can't hurt to give it a run and see what happens!
Btw; You've got a fine Machine there by Wadkin!!
gustafson
Sep 4, 2002
People's Republic
The various options are so cheap [sub 100 bucks] it is virtually not worth worrying about. Buy one use it, kill it, repeat
My Jet Lock is usually right on the fly poop so that does me.
richard newman
Jul 28, 2006
rochester, ny
Funny to have a woodworking forum on a machinist's site, the tolerance decimal point is one over from metal, or two for grinding! That being said, some of us do try to work as accurately as possible, whether it's necessary or not, including me.
I have a dial indicator on my resaw fence, and I use my calipers to get +/- .002" on the planer and widebelt sander. Should put a DRO on those...
hanermo
Sep 28, 2009
barcelona, spain
Any of the chinese stuff resellers dro will be fine.
Just protect it somewhat from excess dust.
Some may have an extra large display dro -- and you could probably mix/match, as the dro is generally a simple +/- multi-channel counter getting fed via quadrature encoder outputs, usually 3-channel.
Quad encoder outputs are the std cheap output any optical encoder gives out.
(these days, at 1/10 the price before)
You basically get rising and falling signal for 2 lines, the lines are called a and b.
So its a+, a-, b+, b-.
Thats why it´s called quadrature, 4 signals.
Some encoders and servos may have differential signals, but it´s basically the same with an extra +/- for each signal to cut down on electrical noise.
So the a signal line can have an a+ and an a- line for a differential output.
The why is that it´s easy and cheap to make optical gratings with tilted diagonal lines.
This means that an optical grating with say 0.05 mm can actually reliably register 4 counts inside the 0.05 mm line, giving an effective reading of about 0.05/4 == 0.0125.
A decent optical encoder.. 50 $
These days the gratings are very tight and uniform and 0.005 mm or 0.001 mm scales are easily and cheaply available.
The signal from a rotary optical encoder is the same as from a linear scale encoder. Generally.
So You get ab, +/-, 4 lines, 5V power, +/-, or 24V+,-, and gnd.
A generic encoder reader counter at 50$ will show you the counts of a quad-signal input, be it rotary or linear (magnetic cheap scales) or optical sacles.
For woodwork ..
any generic basic dro like igaging will work just fine.
Try to protect it from excess dust via bellows of your choice.
Over time, trending perhaps 5 years, the fine wood dust is likely to choke and or wear your scales.
Some of the best guys in the world working with vmcs and tool grinding or carbon fiber have more or less come to understand they need to replace the linear ways every 5 years, no matter what.
Pattnmaker
Nov 2, 2007
Hamilton, Ontario
Bought a wixey quite a few years ago largely for the ability to use it incrementally and get better accuracy. Incremental was largely for a customers whose one off jobs often had patterns of various saw and dado cuts. Not sure accuracy was much or any better due to the flexibility of the mount. I think I pulled it off after catching on the joint between the scales and haven't missed it.
Planer doesn't have any scales at all but I know 1 revolution of the wheel is 3mm. If thickness is important measure after the first cut and last cut before final thickness. Easy to get within .010" with 2 or 3 measurements. Closer is usually either cnc or disc sander to final thickness.
Brian
Jul 20, 2002
Phoenix, AZ USA
We produce DRO parallel fences and flipstops for certain European sliding table saws, Felder, Martin, SCMI. We use DRO components from Fiama, from Italy. Magnetic tape and small battery powered display units in a couple of varieties. You can see the stuff at my website, lambtoolworks.com and I usually have a few options of displays and magnetic banding in stock.
Your only big issue I see is the inputing a specific size. These units can be zero'd and even add a specific offset that's programmed, but as to inputing numbers, they won't do that.
