JasonPAtkins
- Sep 30, 2010
- Guinea-Bissau, West Africa
Hey all, this isn't a machining question, but is one that I think someone in the community will have a great idea for. I'm in the early phases of a construction project which will eventually be a base for my work here in West Africa, including my new shop.
The noodle scratcher of the day seems like it should have a simple answer, but I'm not as experienced in construction of this type.
Being totally off grid, the water supply will come from a tank up on a tower, filled by a solar pump, and gravity fed into the base's buildings. We're making that tower out of steel. I have some nice salvaged 5" round tubes to use as the main legs (20' long), which already have flanges welded to the ends with 8 bolt holes. We'll be pouring reinforced feet, embedded with threaded rod, to bolt the feet to, and then build the tower above it. The reason to do it that way rather than the much easier method of fabbing it in the shop and then standing it up is that I don't have a crane available.
None of this would be especially complicated, except that I'd like the legs to be angled a bit toward the center of the tank so that the footprint on the ground is wider than the weight, for added stability. If we were going to pour the legs straight into the concrete, I think I can envision a way to get them lined up using scaffolding and a plumb line, but since the pour will be setting the allthread and rebar, and then the tube will be stood up and bolted on later, and the rest of the tower reinforcing welded on in place, I don't have a great idea for a good way to get the allthread at the correct(ish) angles - it's going to lean on two axes. There is some play between the allthread and the holes in the tube flange, so there will be some adjustability once the concrete is set and we start to tighten the nuts, but I think the allthread needs to be pretty close, as a couple of mm of slop between the holes and allthread diameter doesn't translate into the 50cm that I need the 6m long tube to come off of vertical.
(Not shown is all of the cross bracing that will be included)
So, here's my best idea so far, someone please do better! My current idea is to make up a piece of plate that duplicates the tube's flange, but just has a stiff piece of 1" tube welded perpendicular to the face, only 4' long. If the rebar assembly is set in the concrete with that guide bolted square to the allthread, then a plumb can be hung from the top of that tube, and if the distance from the plumb to the bottom of the pipe is 1/5 of the distance I want the full 20' tube's head to lean in, on those two axes, then I should be golden. The guide needs to be stiff enough that it's not deflecting a lot but light enough that it's not going to pull the rebar/allthread assembly out of position during the pour. Controlling for the plumb's correct position should be easy, because I can run mason cord offset by that 1/5 amount of the offset, and then the plumb should just hang over the intersection of the two cords. I'm sure someone with exposure to commercial construction has a much better way of doing this - I think I'm proposing an ancient Egypt level solution.
Hit me!
Hit me!
