SoCalHobbyist
- May 8, 2014
- Corona del Mar, CA
Hello everyone, first post.
I'm building a jig for jeweling metal and need a gear rack to work as a linear indexer. I will run a linear guide in front of the rack and set up an arm on the pillow block that will rest at the top of the teeth via spring loaded bearing. I need a gear rack that is 5/8" (.625) between the top left of each tooth. Not the Circular pitch, which I understand is taken from the point between the Addendum and the Dedendum. I believe the rack I'm seeking uses a 25 degree pressure angle. The rack should have an overall width and height of 1" and a length of 6'.
I've tried specifying a rack on a few manufacturer sites but this measurement seems to be outside the normal ones since obviously these racks are designed to work with gears, not as linear indexes.
Thanks in advance for your help.
