alskdjfhg
- Feb 20, 2013
- Houston TX
1997 F800 digger derrick truck, has a Pitman Polecat boom on.
Been a project for a long, but is the current focus. Alot of hoses were dry rotted and split, I've replaced $1800 worth of hose on it (every hose above the rotary).
Went to do a test lift yesterday, and it wouldn't lift a load. Engine was running at 2000 RPM, so should have plenty of flow. And wasn't loading the engine up. Would try to lift, but stop.
Was picking up a tractor axle that weighed probably 2000lbs, well within capacity.
Winch pays out line and raises without a load, boom lifts, and crane swings. So everything is getting oil.
Anything I should test before I pull the hoist motor?
