idacal
- Aug 9, 2011
- new plymouth id
I had a valve bank that got some moisture in it and it cracked one spool internally sitting over winter, that was a fun one to figure out. if it was me I would start by checking pressure and gpm at both pumps its just fittings, time, oil, a needle valve, and a measuring jug. after that start from the winch and follow all the lines and see if there is a valve in the system that's gummed up. if you have access to other hydraulic power units break the lines for the winch off the valve and run it with a known working system. on old equipment it is usually the pump but this last go-a-round for me it was the winch. but you don't have pressure to the winch so it has to be pump or valves a couple of test hoses will allow you enough room to change to a known good spool. valves and pressure relieve units when bad seem to make odd noises, and vibrations pumps do not. JMO
