OT Looking to find out what this bar was made from.
swamp dweller
Jun 10, 2010
Central Florida USA
My wife and I have been looking for something different than the usual barrel for a bar in our camp. She found the bar in the attached pictures and we brought it home. Definitely not a whiskey barrel and obviously something made by adding the top and back to an old something. My question is what was that old something the front is made from. The front is a complete piece with all the banding attached and solid. The protrutions from each end add to the questions. Im fascinated by the look of it but can't stop wondering what it is and what is was used for. Any ideas?
Rickyb
Jan 21, 2011
Troy mi
Cast iron. Possibly heavily patina’d bronze. Bar protrusions are most likely l
tenons to fit a mating bar section or wall.
swamp dweller
Jun 10, 2010
Central Florida USA
Thanks for your input but I don't think it was always a bar. The side boards and top are much newer wood and the shelves inside are new also. I think the front part with the bands and protrusions was something else and was made into a bar. I like the idea of the protrusions being tenons to fit into something else because there are little hooks on both ends where the tenons are. Maybe an old shipping or storage vessel?
rons
Mar 5, 2009
California, USA
Looks like the side of a British vessel from the day when they ruled the seas.
Would look real neat if you cut a square hole in the center and stick a ten pounder out the hole.
Thunderjet
Jun 24, 2019
Looks kind of musical. Like maybe a piece of an old pedal style organ, or piano.
Just spitballin'
M.B. Naegle
Feb 7, 2011
Conroe, TX USA
Not a clue, but IMO it doesn't look like it was cut from a larger section of something, but was it's own panel from something else. I'm with the above suggestion that it's the dash from an old wagon.
I think the "artsy" trend of seeing new things in old unrelated things is fairly modern (1950's and on), but repurposing things goes back to the stone age. IOW, I think someone used it in an effort to be frivolous, or the old thing was somehow memorable and turning it into a "bar" played into the memory. With the exception of people drawing on Roman and Renaissance times, it wasn't common to have nostalgia about common things that didn't involve you.
cyanidekid
Jun 4, 2016
Brooklyn NYC
looks way too heavy to be a dashboard, I think the lugs and slots tell the story that this was part of something heavy duty, but obviously decorated.
how thick are the staves?
are the lugs solid iron?
I'm leaning toward ship part.
swamp dweller
Jun 10, 2010
Central Florida USA
The staves are 1-1/4" thick and the lugs ( I assume you're referring to the protrusions on the ends) are wood wrapped with the metal banding. The top ones are 2" thick and protrude 6" and the bottom ones are 1-1/4 thick and protrude 5". The top ones have a 1" dia. blind hole half way thru them. I will post some more pictures when I get home this afternoon. Thanks for the input. Lots of good directions to explore.
swamp dweller
Jun 10, 2010
Central Florida USA
Here are some more pictures with better detail. Also the banding is magnetic.Bronze was mentioned earlier.
