David_M
- Sep 30, 2014
- Midway, GA, USA
Give the answer in number of turns.
Well circumference is pi x dia, so if one dia is 3x larger the circumference will be 3x larger. So 3.
Thats interesting. In a sense its a matter of where circle A is viewed from. Ie looking out from the centre of circle B or directly down over circle A.
Either way I blame Boozy D![]()
And the Lord said "let there be lulz," and there was lulz.You have to look at the circles not as circles but as lines bent into a circle...but not any circle, a perfect circle with no chords or defects. It's an object of such perfection that no other 2 circles are as perfect...nor will there ever be.
It's nine...if you divide 3 by 1 you get three, then multiply 3 by the answer and you get 9...nine divided by .33 (1/3) is 27.27...the square root of 27.27 is 5.222 multiply that by pi and get 16.405...tan(16.405) is .29, round up to .3 and multiply by 30 and bam 9.
