Chip deflection shield behind the chuck and over the motor and coolant pump. I replaced the sheet metal parts that isn't painted in this picture, it was severely bent:
Electrical cabinet and chip shield painted:
Thread dial parts:
Chip shield (almost) finished:
Wiring and controls done, with a new gasket:
Name plate cleaned and painted:
Tailstock base and traverse mechanism mounted:
Gearbox cover after lots of work to get it flat. It actually had finish coat on it twice before this picture:
Last coat of primer:
Cover mounted and it doesn't even leak. The trick is to put the sealant on the cover, not the gearbox:
Tailstock done:
Most of the the parts are back on:
New cover for the cross slide screw. I made a temporary cover out of sheetmetal but this one is proper:
Cover done, except for paint:
There are a number of things left. Among them:
- Make covers for the taper attachment.
- Finish paintwork on the tray below the apron.
- Get new oil seals.
