In an effort to stem the copious amount of oil leaking from my 16 CY, I dug out the old packing around the shift levers to replace it and found the arrangement sketched below.
The label "brass washer?" depicts a brass-looking surface that I can only see through the annular space and I have not yet removed (and will be difficult/impossible to remove without destroying or taking apart the headstock). I think this may be a packing washer but it could be a bushing.
I wonder if the actual packing for "Shaft A" lies behind that washer/bushing (where the "?" is) and that the packing I could get to, denoted in pink, was put there by someone over the years.
My reasoning is that the ID of "Shaft B" is threaded and there are holes for the taper pins where the existing packing was located. It seems unlikely that Monarch would design threads and pin-holes through parts that are to be sealed via packing.
I would appreciate input from anyone that has repacked or disassembled these shafts. I will also be inquiring with Monarch.
Backup image:
https://i.imgur.com/kaQzbWT.png
Backup image:
