Part Ejector for 16C Collet
Flash Gordon
Jan 29, 2004
Chicago, IL
I have a Mori Seiki sub-spindle lathe that has 16C collet chucks. Right now, I'm using a Hardinge spring loaded part ejector in the sub-spindle.
It works ok for short parts, but not so good for longer parts. Is there a better product on the market , or does anyone have a design that would work better?
Thanks!
G
Guest
Guest
I believe the design of the sub spindle is going to dictate what you can use. Didn't the machine come with an ejection system or was one an option? I scrapped a machine a couple years back that could eject pretty long skinny parts. It was just a rod assembly with an adjustable collar that came with various length springs, but it was part of the sub spindle assembly and not the collet. I thought I might have saved the guts to use on something else,but I just checked and it must have went to the scrap yard. I might still have the book on the machine that has a drawing. That would only be of use to get an idea on what to make if the subs were similar in design.
Kapster
Dec 17, 2013
Ohio, USA
I recently had to figure this out on our new nlx lathe. What model mori is it? Ours has a draw bar (non through) on the sub spindle with air through it to part eject. It came with an ejector for the 6" Kitagawa. I made a similar pusher but one that threads into the collet.
Perry Harrington
Oct 7, 2006
Klamath Falls, Oregon
What Kapster described is basically a Hardinge 5C collet bar feeder.
I built one for a 16C collet that's about 1m long.
Basically it's a DOM tube with a pusher that is conical, to receive the end of a bar and prevent whipping.
A cap on the end of the bar has a rotary union in it, with a push-lock air fitting.
A nylon 1/4" air tube goes to a pressure regulator that's adjusted to a low air pressure, enough to engage the pusher, but not resist the pick-off operation.
Then you just screw the DOM tube into the back of the 16C collet where the normal depth stop goes.
Ox
Aug 27, 2002
West Unity, Ohio
This is a set that I made up for a 16C sub-spindle 20 yrs ago.
The unit has came loose a few times over the years on long runs, and buggered up the threads to the point that there's not much holding it anymore, and I may need to remake the one piece one day, but otherwise it works good.
She swallows pretty long parts - which is why I had'ta make it to begin with.
The actuator is a feed-out spring from a 9/16 Acme that I shove up in the spindle and bottom out.
I may have to shorten it a bit to work? I don't recall for sure right off the top of my noggin ... :o
I have a slew of tips that I change per job, from a 5/16-18 stud up to - something close to 1.625 I s'pose....
It's not fancy!
10" Record
Ox
