I have a 5 HP 3-phase manual lathe. The lathe includes a 3-phase input VFD for variable speed control. The lathe also includes two other 3-phase motors for oil circulation and coolant. I don't have 3-phase power available at my location. I use phase converting VFDs to drive my other 3-phase equipment. However, in this case, I probably need a different solution. I already have a large American Rotary phase converter, but VFDs don't like to have frequent on/off input power cycles and I don't want to leave the rotary converter running all the time.
From my limited understanding, I have a couple options:
1. Supply phase converted power to the lathe using another VFD. I suspect this will not work, but want to confirm since this is the cheapest and lowest hassle option. I'm guessing you can't "string together" VFDs in this manner. I don't know, buy strongly suspect, VFDs are primarily designed to be connected directly to motors. However, if the frequency is "locked", could a 1-phase to 3-phase VFD be used to "drive" a 3-phase input VFD?
2. Replace the existing VFD with a phase converting VFD. That might be tricky due to the wiring. And, I'd have to address the other motors.
3. Purchase a stand alone phase converter of good quality, like a Phase Perfect. They seem to own the market based on my limited research. Do other companies produce similar products?
Of course, there are other options but the cost of the alternatives out way the benefits (i.e., it's cheaper to just buy a stand alone phase converter and be done with it).
