Hi All,
I'm trying to change my machine language,
I use password 1234 to edit machine constants ,change the value in parameter 5 but the machine remains with the same language,never change.
Any suggestions??
Thanks a lot !
My 532 VME has only the SRAM SSD HDD but my comp-tech buddy was able to copy what was on it but he doesn't think it will help much if it does in fact get wiped. As I understand it, there were disks that could be used to boot from that would allow initial use of the SSD to get it working. It hasn't come up but it may already be configured in the BIOS for this type of motherboard and just is a matter of temporarily adding a HDD, configuring in the BIOS and transferring files. I am not certain the older V3xx series control software was setup to allow a larger HDD to be used like in the newer "Millplus" controls, does anyone know if this was an option?
hi all
In dmu60p / milplus device, after not working for a while and losing the initial parameters and reloading it, we have encountered a series of problems, including error e252, which is related to the tool gripper sensor, which is not present in our device. . We can not find a solution to this problem anywhere. What is the solution to this problem?
We have done all this. I think we should change a choice in the constant parameters, but we do not have a manual for the parameters of the machine and dmg mori does not provide any help.
I think there is a troubleshooting book for dmu devices but I do not know where to get it.
I'm sure many technicians have this problem.
Regards.
I do have a full set of backup discs for Millplus V4.0 for my DMU50v. Ive copied these in case anyone needs digital versions to rebuild after a trashed drive on the same machine. Pretty sure all youd have to insert your machines parameters into the flies to replace my shipped parameters.
Notice
