"planer" for aluminum lat bar? is that a thing?
BT Fabrication
Nov 3, 2019
Ontario Canada
I guess a multi axis head huh?
When all you have is a hammer….
I never even thought of a tilting head to cut it all… what kind of dimensional tolerances and wall smoothness can be achieved? Not that I need anything wild, just curious.
no, laser cut general shape out 500 pcs at a time oversize. bolt to fixture enough to cover entire table and hit start. 32" long table can do min 8 pcs per cycle start if one row. now imagine 5x that if its 20x32" 40 pcs in minutes. 500 done in hours and not a whole year.
laser can be plus or minus 0.003"
Peter Colman
Sep 22, 2004
Rugeley UK
If you make the discs and use a vacuum table with a stop on the thrust side to hold them, you should be able to mill them flat.
The table would have to be made to deal with the holes or drill them after.
TaperPin
May 29, 2023
You aren’t making a lot of parts and tolerances aren’t tight, so a wide thickness sanding drum as you’d find in a woodworkers shop would seem to work. These have a motorized belt to feed the material and the abrasive paper is only a few inches wide and wrapped around the drum in a spiral and secured on the ends.
Im no expert on these, but a middle of the road version that I’ve seen operate would probably be able to take off .005” per pass with a coarse abrasive on 4” wide material - not much more since the motors are quite modest - no, material removal just plain sucks.
Even in a hardwood board 8” wide in something like oak you’d be lucky to take off 1/32” (.031”) per pass with fresh paper. The rubber feed belt won’t produce great consistency as the belt wears.
I know nothing about grinding wheels for aluminum, but a simple 15amp 115v motor with cup wheel mounted over a bed and a simple height adjustment, paired with decent guides could be hand fed if you weren’t too aggressive.
Knifesmiths have rigged up all sorts of contraptions to thickness blades - a belt sander set to a certain gap over a bed comes to mind.
I‘d say a hard no to using a wood planer - the feed system requires the part to skid across the bed and the feed rollers would quickly get aluminum imbedded and stop feeding. Many things in its design require the material to be somewhat soft and forgiving.
If I had to do it today I’d use a big 15amp handheld wood router with the depth built in to a guide in the baseplate and make 4 passes, but I’m quite familiar with the machine, making odd guides, and have good quality bits. 4 passes is still 480’ of aluminum 1” wide and .010”ish deep and I don’t have a frame of reference for how well wood cutters would hold up - probably have to be sharpened a few times at best. An overhead router with cast iron base would be ideal as far as routers/shapers go.
A cold saw cutting disks from round bar would get you within .005” with a simple stop if it wasn’t worn out - I can get that from a wood cutting chop saw. Hell a cheap bandsaw with tight joints, decent roller alignment and new blade would as well.
Let us know what you try and what works out!
Garwood
Oct 10, 2009
Oregon
Blanchard. It would be crazy fast to do these on a Blanchard. No workholding whatsoever to worry about. Tip the tram so the wheel's leading edge is a thou or two high. Run a chuck ring and you can do 10+ per batch every 5 minutes.
Garwood
Oct 10, 2009
Oregon
They're aluminum, Gar. I know you love that thing but magnetic chucks don't work well on aluminum :D
I agree you could but it might not be the easiest way to go ....
And what does Carbide Bob grind on his Blanchards?
That step around the chuck is for a ring. The ring is for parts you can't hold with the magnet.
You tram the spindle a tiny scoche up on the leading edge so the back side of the wheel pulls the parts into the chuck ring.
EmGo
Apr 14, 2018
Did you change the wheel ? That's not much fun on a blanch, and the wheel for hogging steel is not going to be happy skimming aluminum. Ja, you could do it but wouldn't be my first choice ... or second, or third. Have to go with the Timesaver idea, myself.
Grinding aluminum already kind of sucks .... and these guys are skinny, and light, so coolant gets under them and they come off the table a little then hit the wheel .... I don't think it would be fun but could be mistaken. You do it and make a video :D
But maybe while you have that thing turned on you could grab this spammer and run him through there ? We'd pay to watch !
Garwood
Oct 10, 2009
Oregon
The segments I'm running are almost as smooth as brushed concrete. I don't think you can load them up.
4GSR
Jan 25, 2005
Victoria, Texas, USA
You are going to need more than a helmet for protection from getting hit by them pieces being chunked off that Blanchard!!! Yikes!:eek: I've been around a few in years past, never operated one, but the thought is what scares me.
EmGo
Apr 14, 2018
While we're here messing around with Stirling's money :) how about a vacuum chuck and a razor-sharp flycutter ? (Not to the plate, cut them up into part-size chunks first). One quick pass across the top, make it look pretty as well as being the right thickness ?
(Don't even say it, Gar. I know what you're thinking.)
memphisjed
Jan 21, 2019
Memphis
Rolling mill. Just have guides to keep bar kinda straight-ish. You are bolting these bars to angle in the steps two down from this.
Or just bevel head laser.
Better yet, bevel waterjet. Near perfect edge quality
Overland
Nov 19, 2017
Greenville, SC
If I understand correctly, you're looking for 4" wide strips of aluminum 1/8" thick.
Does your supplier have a shear ?
Surely 1/8" sheet is pretty consistent ?
Wouldn't this be an easy way for you to get good stock to start your process ?
Seems too obvious.
Bob
Garwood
Oct 10, 2009
Oregon
One of the tricks Blanchard shows in thier manuals is making a mask for the chuck with windows for non-magnetic parts. The chucks have bolt holes between the coils for fixturing.
I'd try the ring first. I've been amazed what I can grind without it moving.
EmGo
Apr 14, 2018
Maybe you missed this ? "im struggling with obtaining aluminum flat bar that meets dimentional tolorance these days" I don't think he'll be much luckier with plate, we're complaining about a few thousandths here .... belt sander, imo.
Unless .... Garwood's pretty good with the blanchard idea, but I think Stirling should go full-on. Change to steel, a man's material, and make his own strip, so he could control thickness better
Or go for castings, then he could control materials chemistry and use gar's blanchard !
plus scare all the neighbors and make his insurance company wet their pants ...
but personally, if I went to all that trouble, after making the bar I'd want to forge it for strength, then could still use that blanchard and most of the other cool facilities :)
Stirling just needs to expand his imagination a little ...
Garwood
Oct 10, 2009
Oregon
It's funny. If you search this site way back you get a handful of folks recommending Blanchard grinding aluminum as the fastest way to size aluminum flats. You get segment recommendations, and general praise for the process. There's a whole section in the Blanchard "how to use a Blanchard" book on grinding aluminum.
I don't think I'm totally out in left field for recommending it.
Dealer's selling Blanchards want stupid money for them. A No. 18 at auction doesn't often go for more than $2k. For a machine that's dirt simple, costs nothing to run and works semi-automatically I don't get why every shop doesn't have one.
Garwood
Oct 10, 2009
Oregon
If you get bored some time, toss some 1/8" aluminum up on the chuck and go for it ? Tell us how it worked out ?
I'll probably have to eat crow. Can I substitute pigeon ? It's easier to get.
The one chuck ring I have sticks up a lot more than 1/8". That's the only thing preventing me from walking over and trying it.
If the OP's plates are all the same at qty 500/yr it seems like a masking plate would be a given instead of just using the chuck ring. I can't see how it couldn't work with a masking plate.
