cuttergrinder
- Mar 16, 2007
- Salem,Ohio
Last week I had a job at work where I had to drill 8-13/16 holes and put in 2- 1 1/4" flat bottom holes in some 4140. The flat bottom holes are nothing critical, only clearance for a bolt head.
I have been a machinist for over 30 years but this was on manual machines such as cincinnati verticals and g&L horizontal boring mills. On these machines I would put in 1 1/4" flat bottom holes using a 1 1/4" 2 flute high speed endmill and just plunge it right in.
Since we just purchased a Mazak vtc16 cnc mill, I was using this mill and using a 5/8" carbide 4 flute center cutting endmill. I was using the mazatrol and if I remember right, the mazatrol programmed a feed of .008" per rev. I programmed a step down of .150". I backed the feed way down but the machine just did not like plunging with this 5/8 endmill. I ended up drilling the holes to depth with a 13/16 drill and then profiling the holes.
How would you guys go about putting in these flat bottom holes on this machine? What kind of feed would you run and what step down you use?
