So I'm programming a part that need's to be reamed to size. (Ø.201) The solid carbide reamer that I am going to use is 3" OAL, and is ground between (reverse)centers. (There is a point on each end where the reamer is held.) In order to compensate for the length past the pointed tip, I need to know the angle of the tip. I could just measure it once it gets here, but I'd like to know the length of the tip without needing to do that. It doesn't look like a 60° angle to me, but I could be wrong.
Is there a standard angle for grinding tools with this method?
