Polishing aluminum in machine
aandabooks
Oct 24, 2009
Illinois
Hello,
Looking for a solution for polishing aluminum parts in machine. Primarily I run 6061 bar stock for the parts that I make. Since most is through hole or reasonable tolerances I don't face mill before machining. I worked for a company that experimented with some brushes on cast aluminum parts with mixed results.
I would like to be able to run a brush/polisher at the end of the program and then flip to do the other side. What are some solutions that I can look at for reasonable speeds and effectiveness?
EmGo
Apr 14, 2018
There's a Japanese place that claims their brushes are super-special effective. I've seen them at shows but hey, everything works perfect at shows. Anyway, US site here
if you try some, then it'd be nice to report back ?
F35Machinist
Nov 3, 2021
California
Facing with a MCD tool will result in a mirror finish in aluminum. That is probably overkill if you are anodizing after and you would probably get away with just facing the part with PCD or polished carbide inserts.
