evil monkey
- Feb 5, 2023
Items you will need: 4.5" depressed center grinding disc with 5/8" center hole , 3/4" round stock about 6 " long , 1 1/4" or 1.5" round stock, a 5/16 nc tap ,5/16 socket head couter sunk screw , washer that fits the ID depression of the depressed center grinding disc, a counter sink or center drill for the washer.
I will share this idea assuming people on this site, still typing, have common sense , most of their fingers and at least one eye .
Drill your 1 1/4" or 1.5 stock for 5/8" to a depth of about 1/2". cutoff a spacer about 1/4" thick, face one side. You can cut it thicker , this is not critical, you will face the other side later. Turn your 3/4" 6" stock down to a few thou over 5/8", for a distance up the shaft 1/4" plus the thickness of your grinding disc center depressio. You want a snug fit on the grinding disc center hole so take some time here. Relocate items to welding table. Slide the spacer on the shaft with faced side to shoulder and tig or stick weld in place. About three tacks around the shaft with good penetration. Return to lathe and face the side that will face the disc. A good facing job is necessary. . Check fit for disc and washer and either face a little more off the shaft or the shoulder so the grinding disc sits flush with the end of the shaft. If you faced the outside shoulder carefully and the disc is snug on the shaft you are ready to drill the center and tap for the 5/16"NC screw. Assenble the disc , washer and screw. Counter sink the washer so the screw fits flush. Everything on this side should be below the grinding surface.
Run your verticle mill clockwise so it always tightens the disc screw while grinding "because you won't like the taste of grinding disc running it counter clockwise". I use a moderate to slow speed and limit grinds to about .003 max. Moderate speeds and low feeds will give a mirror finish . I have run coolant during a grind without any problems other than it's messy. This doesn't replace a surfce grinder but it works well on vise jaws and similar width projects .
